Shigaclone MKII Black - The builders Thread
A proper sized 10nF silver-mica could be best noise killer.
If you can verify that 10nF is making a difference or works as intended, I have some very nice quality Cornell Dubilier silver micas I can try.
They are big though.
By the way, since we are gaining the 3-4mm on the pcb by soldering the cap on the solder blubs there and not on the pads, don t we have some slack to use a bit bigger leads?
Unless soldering it even closer makes some difference as well
You may test and let us know.
This 100nF cap is there to kill any kind of noise, not only from power supply, but also from and induced RF trough ribbon cable.
The main rule is that whatever you put there, must be connected as close as possible to laser diode.
Tibi
In that case, replacing the ribbon cable with tightly twisted and shielded pairs of wire should further reduce RF interference and/or inductance.
We may even not use the plastic clips on the pcbs, but solder the laser wires directly as close as possible to the relevant inputs/outputs.
Yes and no.
Current signal collected by pin diodes can be affected by parasitic capacitance of shielding. Ribbon flat cable is constructed in such way to keep this parasitic capacitance at minimum between pin diodes and also between each pin diode and ground.
On other hand, cable to laser and monitor diode can be shielded and may improve performance.
I totally agree with soldering the clips to ribbon cable.
Tibi
As I said the cap is 100nF X5R.
Almost any capacitor will be better, but must be small enough do not affect mechanic operation. Also big caps with long leads are out discussion here. The cap must be as close as possible to laser.
My choice is Arcotronics MKT. It is good, cheap, have exceptionally low ESR, and small enough to be soldered directly on laser pins.
Another candidate could be VISHAY-RODERSTEIN MKP-1837.
Here is the cap in his new job.
Tibi
Tibi,
Is this mod part of the high grade kit, or will I still have to do this? My Shiga should be here soon. So I like to know so I can order part if needed. Thank you.
Tony G
Tibi
Thank you Tibi,
5 minutes work and here it is the MKP1837 on laser board .
Sounds really good ,there is more control of everything but the most is the better control of sound stage,a more sharp image.
its deffinitely worth this mod
All the best
Nicu
Now, I'm very tempted to replace another two small X5R caps.
One is Vcc decoupling on photo-detector and another one is Vref decoupling for the same photo-detector. Unfortunately these must be small enough to fit the space and as close as possible to photo-detector chip. I'm looking for a solution ... will see.
Tibi
Your talking about the two at the bottom of the eye near that small ribbon cable right? Yeah they are pretty small with very small space around them. Perhaps if they are soldered on the chip's leads directly? Although it should be VERY sensitive to heat...
I did the test today and did some fast listening before going to work.
Definitely an improvement, although I still have to pinpoint it. The system did not play for a week and might have been a bit numb.
TOC reading was definitely faster and smoother, and cdr playback was also with less skips in my mk1. There was some new skips on a plain cd though.
The sound gave me an idea that there was more low volume details. Spatial microsounds, drum tickles, bass string plucking etc.
Bass and mid lows seem a bit thinner, but I will give it a bit more time.
A minor problem, the cap is thick and when the sled goes to the end of its travel it slightly touches the plastic wall (sanyo mecha)
By the way on my sanyo mecha the original cap was soldered even further away on the pcb. There was about 10mm distance from the solder joints
Please, test on MKII.
Tibi
I just finished building it.
First audition in moderate levels and I must admit that I am impressed. MK2 sounds wonderful.
Tracking is through the roof accurate. It managed to even read and play a few tracks on a Verbatim CDR that not even my PC reads.
Something that I do not like is that the LCD's light flickers while it accelerates or breaks the spindle motor, indicating that I am having some voltage drop. This probably also causes it to have to scan twice to read the TOC. This could be because of the Sanyo mecha. I think I had the same issue on the MK1 initially. Do you guys have something like that using the standard mecha?
Sonically the thing is superb. Even unmodified I am getting new stuff in the music. Granted it is a bit mid-frequency centered, but still I am getting more resolution in that area. And without any of the standard mods.
Next stop: C11, C8 and mini-regs.... but that is tomorrow :)
Tibi where should I try the two miniregs? V3-V4?
Dimkasta,
There should be no flickering of backlight while cd operation.
Please check your power supply, check LCD backlight soldering, check R55 soldering and P1 strap.
Miniregs on V3 and V4. See my previous posts in this thread.
Tibi
