replacement tweeters musical fideleity mc4 speakers
hi all,
newbie on this forum, and i hope someone can help me, i have just purchased a pair of musical fideleity mc4 speakers (version 1), and am in need of replacement tweeters, any advice on what tweeters/how to find a dealer?
any advice or tips i would be very gratefull for :)
boredsurfer
thanks dublin78, have emailed niel, in the meantime i got a response from toaster in wrong forum (me newby) :eek:, but i thought it worth quoting him here -
'Hi boredsurfer, you'd be better putting this on the 'multi-way' forum, but I should think the obvious replacement would be the SEAS 27TBFCG aluminium dome tweeters. No doubt the crossover network would need to be modified to suit. The TDL tweeters are long discontinued of course. I suspect I was the first DIY user in the UK to buy a pair. I ended up using them in a couple of designs, one of which a friend of mine still uses- still sounds good too! Good luck with the repair. '
any comments or further info on this would be great, but i have one question, if i biwire the speakers will i need to modify the crossover network? as i said im a complete newby, lol:D
I have a pair of Musical fidelity MC2's (mk1). The tweeters are metal dome types, they were made by Elac.
i am wondering if they hare the same tweeter as mc4's (mk1), i found some info on another forum about mc2 mk1 tweeters which sounds almost identical to mine he said - 'the label on the back of the (tweeter) unit is printed "MADE IN THE UK" and stamped 25DT 34 348 8Ohm'
mine have same label, with 25DT 34 398 9 Ohm, his MC2 mk1 have same tweeter housing as well, would they be a possible replacemnet for my mc4's? :confused:
correction 8 Ohm, lol
Disabled Account
Joined 2010
For future reference in this thread, I have a pair of MC4 mk 1 and the other day I bought some monitor audio R952/MDs and Monitor 9s (late 80s?) and the tweeters on these look just like the MC4's (except for the different company logo) and sound just like them so I suspect they are indeed the same!
MC4s too bright
Hi all, my MC4s (V1) are overly bright but the tweeters sound fine with no distortion.
So where is this brightness coming from ?
Have the woofers become lazy ? or is this all down to the crossover (caps) ?
Took a look inside and all is original and untouched.
Only took a close up of the xover caps for the bass, but the highs have the same capacitors again.
Date stamp in the cab says Sept 1987
Possibly the metal tweeters are not set to your taste. There's a thing in the industry called showroom brightness that sells speakers, but they get on your nerves when you get home. :D
Looks like Musical Fidelity also used this similar common H0532-08 19TAFD/G tweeter.
I'd have to see the crossover schematic to say what you should do here precisely, but you'll probably add a tiny bit more resistance (maybe 2.2R) to the treble filter input and shunt a zobel (7.5R 7W wirewound resistor and 0.68uF polypropylene capacitor in series) across the tweeter to tame it. Very easy actually. You can get the bits at Maplin. :cool:
I take it you have the below model. Looks like polycone and metal tweet. It is common enough for ferrofluid, if applied here, to dry out and solidify. But that usually just stops the tweeters working at all.
It's some sort of minimalistic design by Martin Colloms as I understand it. Uses the Rogers 8" bass AFAIK. Bit like some Epos designs.
The schematic is something you work out from observation. I'd expect a coil on the bass and maybe an RC shunt, and a capacitor and resistor to the tweeter at least. Perhaps a coil on the tweeter too. Bit like this maybe, but not too interested in coil values anyway. Resistor and capacitor values are readable.
Those plastic capacitors really shouldn't age. But some connectors and joints could be corroded or dry jointed. Crimp connectors to the drivers might be worth pulling off and reconnecting for fresh metal. It's worth noting polarity before you disassemble though. Otherwise you're scratching your head to get the phase right!
Bear in mind that frequency response IS slightly affected by amplification type too. Valves sound very different from solid state. They interact with speaker impedance more.
ah ok so the bass was made by Rogers, interesting not heard of them doing anything but radios for a long time.
Yes my amp is valve, but got 4 pairs of speakers here and the MC4s are by far the brightest. They are known as being rather bass heavy by design !
I imagine some new ClarityCaps would blow the pants off of those installed here near thirty years ago anyway
I never spend too much on capacitors these days. Good 250V polys are quite adequate. Get 400V types if you've got room.
Capacitors
Now come on. Work out the schematic. I can then tell you why they sound bright and how to fix it. Soggy bass is a given with valves. They don't drive reflex too well. Something to do with damping factor, or lack of it! :D
