1000W Simple PA Amplifier
The 1n540x is much bigger and requires much bigger through holes for mounting.
I also fit 1n4003 across the first decoupling caps (after fuses, if fitted). This protects against accidental mis-wiring of the PSU cabling (it turns on the light bulb, or blows the close rated mains fuse).
These four 2cent, (1.5p) diodes are life savers.
Ex-Moderator R.I.P.
Joined 2005
for the 2SC5200/2SA1943 driver stage, I suppose Fairchild devices will be ok
due to the almost 100% non inductive construction, a power thick film appears attractive for the 1R emitter resistor
and not too costly either
but is it ok for this position ?
forced air cooling ;)
I know, but this heatsink even small with forced cooling too.
possible only with the protection curcuit shutting down if fan fails or amp is overloaded
Yes, the protection will help to avoid the failure resulted by the overheating. However the amplifier will stop, and this is not a good solution for professional application.
overload detector for 1000 watt AB CLASS
Hello
greetings can anyone share overload and low impedance detector for this amp cabinets are ready supply pcb has clip dc protect temprature shutdown
filter caps would be 15000 uf 4 caps only wish if overload detector circuit can be added
warm regards
andrew;)
