Plenty of vertical mount ones but horizintal mounts are thin on the ground.Where did you find your capacitor clamp? Having trouble sourcing one this big.
I may just go the zip tie route that overs have used.
Trip to Home Depot first though as stuff often turns up there.
Sorry, Just noticed this question. I got it at mouser
Part number 539-VR10A. It's a vertical clamp. I just bent the tabs. It was also actually to big, so I redrilled a hole for the clamp screw.
Can't beat DIY
I just was not happy with the first chassis for this amp, it did not do it justice.
Hi trooper,
really nice work! How did you mount the PCB? I hope to learn for my build.
Michael
Here's mine with Trooper's first chassis!! I like Troopers first chassis very much.
Pcb mounting
Zimmer64 I've been using these to mount the board
https://tubedepot.com/products/number-6-female-female-hex-aluminum-standoff
You should be abil to get them at your local hardware store.
Thanks again Bob! I can't wait to see the mono blocks!
KT150s? How do you like them?
Love 'em! Boywonder is spot on, a Jetson Amp
KT150s yes I like the sound VERY much, I was just going to take a listen to them for a few days and they've been in ever since I bought them, month and half or so.... I'm going to build another with those output tubes in mind, beef things up some more add more voltage and no electrolytics in the power supply. They replaced GL KT88s and sound better to my ears with VERY efficient horn loaded speakers with BIG 15" woofers...
Bob
First Time Tube Amp Build
This is the first amp I have built. Still needs to have motor run cap added, knob and power switch added. Sounded great but I may have a bad tube. Kinda bummed but should have replacements next week.
Test for pic post
001
Could someone please tell me why my pic does not show up?
001
I'm not sure... I'll give it a try
no doesn't work for me either...
OK this is better.... see the attached sceen shot. I chose the forum type for copying the url.
NNote that you should resize the images before uploading to a picture sharing site. Better is to attach them to the post. This can be done by going into the advanced editor.
Tony.
Tony.
- More Vendors...
- Tubelab
- Pictures of your Tubelab amp
