Home Brew PCBs
£150 - YES !!!
The company that I use is in America. The cost for 2 x boards (their minimum) is approximately £80. Then add P&P and Handling - approximately £30. Then the criminal bit is UPS then add a further UK handling charge of approximately £30 which includes Import Tax.
I appreciate there are cheaper options but these guys are VERY quick, I usually get the boards two to three days after ordering.
Send them to me and maybe we can work out a way to get them to you cheaper.
I never got on with making my own pcbs. It rarely worked was messy and time consuming ending up with a amateur job.
I found a Chinese pcb supplier who turns the pcb's around in 2 weeks to my door. He is very cheapo, about 1/3 of the cost in the UK.
I get great professional looking pcb's and have never had a pcb fault.
Do yo have a link to the pcb supplier?
And what software do you have to use when you send them an order?
Toner transfer paper has been around for some time. Most of them will transfer the image very well using a dry iron on low. Make sure the copper is very clean. Scrub it with a Brillo pad to get it nice and shiny. Use latex gloves to avoid finger prints. Works great for silk screening single sided boards as well.
Oh dear another dismal failure
I really thought this might work but NO, another dismal failure.
Now, image 2 was printed on normal 90gsm paper using my Samsung ML1665. The printer is working fine it just doesn't like the TTP (Toner Transfer Paper).
I've got a packet of 8 sheets left if anyone would like to try it. (Call it a £5 incl P&P).
After many weeks of experimenting I have come to the conclusion that any form of toner transfer is a waste of time. The results are unpredictable and the final product is invariably poor. I've tried many many laser printers, even when using the capable HP Laserjet 600, which will print onto the TTP, the image still wont stick to the copper clad board sucessfully. I've tried numerous laminators which all failed, even ironing it with a domestic iron was a failure.
The only repeatable good results are when using photo resist boards.
Now, photo resist board isn't cheap, I'm just trying some photo resist film that our Oriental friends are selling on E-Bay for £0.50p a sheet (only A5 - but that's big enough for most projects).
I've just managed to stick a sheet of it to a bare copper clad board, I'll try exposing it tomorrow with a UV source and I'll let you know how it performs.
This might sound STUPID, but I've spent over £1000 so far trying various printers, medium and techniques. The best so far is using a Ricoh GelJet printer to print an opaque image onto clear acetate film. Buying nude copper clad board from China and then using a laminator to apply photo resist film to the board. (This is far superior to trying to spray photo resist onto the board). Tomorrow - I've already said this above.
Joined 2004
Hi KatieandDad :)
I use the toner transfer method, and it works very fine. I use a Samsung ML-2165 printer, this is a cheap printer, with results as good as what I could get with the photo resist method on a PCB.
I use a GBC H425 laminator, that works perfectly with it.
What you have to find is the right paper to be used ... I have found in my local super market the pub on a relatively thin paper that makes wonders with my printer (It is used with a white paper below it and adhesive tape to fix both papers together as the thickness of the thin paper is not sufficient for the printer, the thin paper would not do it through the printer. The adhesive tape is the one painters use in your home in order to avoid painting in places not wanted).
I have also tried a lot of different kind of papers ... and I report only bad or insufficient results. The paper IS really the solution. The good new is that pub comes free of charges ... and when you have found the "good pub" for your application, you can get as much paper as you need ... for free ;).
It is a simple method, no chemicals are used else than HCl from the supermarket, and the H2O2 (the good one is sold in your pharmacy, it is the concentrated one, difficult :mad: to get, but if you are able to pray :bawling: the right way ... it will come).
It is also very easy to dispose the used (liquid) chemicals as this liquid used with NaHCO3 (sodium acid carbonate) will produce many bubbles (it can be dangerous, pay attention to this part) and a blue solid precipitate that you can throw in the bin.
Don't surrender, find the good paper for free, and ... be happy :D with nice PCBs done all in one in less than 60 minutes !
Best regards
rephil
The biggest issue I have had so far with Toner Transfer was having an iron with not enough heat!!
Used 3 different ones until I found one that worked great!
The one I found that gets hot enough has a mechanical thermostat on it.
The electronic ones I used where just a tad below what I needed to get a good transfer and I got it at the goodwill store for $3!! :)
Here is my results after a few practice tries in order to get the hang of it,
http://www.diyaudio.com/forums/construction-tips/221683-smd-soldering.html#post3685868
FWIW
jer :)
Joined 2004
What is "pub"?:confused:
Hi Godfrey,
Sorry :eek:, pub = publicité, it means advertising. I have not thought that this was only to be understood by french people. Again sorry ! I am speaking of these very low valued papers given for free to all people in the super markets as advertising : they want to sell some products. This paper is thin, shiny, with text and partly coloured. You have to find the good :) advertising, not all papers are OK.
Best regards
rephil
Well the first attempts were failures.
My fault entirely.
1. I assumed that the ex[posure time would be similar to that of photo resist board (ie 2-3 mins). It isn't it's about 3-6 seconds.
2. I've been using Caustic Soda for developing which may be a bit harsh.
Anyway, I've got the correct developer on the way and I'll try again.
As for toner transfer, I tried all manner of paper, including cheap magazines and none were reliable.
