maybe you guys should start a kickstarter project to gather some R&D funding....
+1
Could you handle this directly with Subbu just the way you got the boards. I don't think the world needs to know any small inconvenience that might occur getting boards, BOM etc. nor will asking all members solve anything.
Just think how things went in your case and multiply that by 500 and think that we do this all in our spare time. Thank you.
Hi everyone,
I just start to build this DAC. I got a quick question. Can I use 12.8Mhz OSC for WM8804? Since I heard the 12Mhz is only for internal circuits to work, WM8804 will use PLL to generate output clocks. I ask because I found a very high quality 12.8Mhz OCXO, and I'd like to know if I can use it.
Please use 12 MHz. Don't listen what people say, better read the data sheet:
http://www.wolfsonmicro.com/documents/uploads/data_sheets/en/WM8804.pdf
Page 30...
Page 30...
Page 30...
Thanks. That explains everything.
- Group Buys
- ES9023 / WM8804 S/PDIF "Subbu DAC V3" GB Interest
