Keep registering lower current in the lower half... is it normal ?
Plot I(R17)-I(R16) and all will be revealed
I must say there are some compromises here..... difficult to use use another psu... can I keep the lovely 103 +-35v psu ?
Can I use other trannies (other than BC546/556) ?
2sa970/2sc2240 for instance
2sa970/2sc2240 for instance![]()
Like here.
Change Q6 and Q12 also (Vce is borderline)
Can I use 2sa970/2sc2240 for Q6 Q12 ?
Where can I find the Toshibas ?
Yes you can!
In my transistor box
Hey Golden Titian Top, whats with .ASC files???
You trying to keep us elderly lightweight Mac guys out of it???![]()
And for those who can't
You could install Wine http://wiki.winehq.org/MacOSX]
Or use parallels ]Run Windows on Mac - Windows and Mac side-by-side with Parallels Desktop 9 for Mac - Parallels
Or just miss the fun
Or get a real PC
So when the bias resistor is 165 Ohm R1, R2 are 115 Ohm ?
I do not see any Miller cap in this design.
Is the circuit stable without it ?
i did not yet test for stability, has to be done yet.
R1/2 need more work.
I am using the 49710 opamp... but with 100p miller cap.... this is a good sign.....
Now, why do you use three transdiodes and not only two and increase the bias resistor a little bit ?
And here is something special indeed: Krylov - Bach - Toccata and Fugue - YouTube
This guy (Sergej Krilov) might as well be the highest violin player alive![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
actually 10p (not 100p)
Still working on that, bias generators are a PITA
Many thanks.
What is the frequency response ( -3dB ) with this setup.
Soon ...
- Analogue Source
- JG´s Nobrainer and Nobrainer Discrete
