Hi guys.
I've some problems with my new mic/Behringer 8000 with Clio 10FW.
I've measured three tweeters (R29, D30 and SB29). The pattern/peaks are the same every time.
Here of the SB29 - mls and sinusoidal.
What causes this ? Any thoughts ?
Thx.
Thx.
I'm not familiar with Clio, I'm wondering whether you are getting feedback. Also strange that there is such a big difference between swept sine and MLS (they should be almost identical).
Check your sound card settings and make sure that what you are recording is not being sent back out to the speakers (often a tick box called something like "record without monitoring").
You could try downloading holmimpulse and see whether you are getting similar issues, this will give you an idea as to whether it is a hardware or software issue.
Tony.
Tony.
Hi Tony.
Thanks for your feedback. I've tried different soundcard/Clio-mic settings in the software with no succes.
I do not understand the big differents between the measurements.
Whatever is measured in the sinusoidal mode, does obviously occurre in the MLS to.
But i've no clue what causes it.
Any respons is most appriciated. I've written to audiomatic and awaiting some feedback from them.
Thanks for your respons, guys.
Marsh -> He is pic with the D30 mounted in the speaker:
Barley -> What do you mean by "driving the tweeter with" ? No, i've not yet verified if the mic is defekt. I'm not using an amp - as far as i understand, i can just use the internal amp with Clio 10FW. So Output-> XLR/crcocodile is directly connected to the tweeter. In the manual it says, it's no need to use the 12V input, when i'm using firewire 6pin/6pin cable.
VaNarn -> Oh my.. what kind of supply, would work with the mic and my Clio ? Bare with me
No, Clio 10FW do not include amplifier which can drive loudspeakers directly. You must use CLIO QCbox model 5 power amplifier, or any hi-fi amplifier capable of several W output.
Are you doing ground plane windowed measurements? The measurement window looks wrong per your plots. You are getting input from reflections and possibly ambient noise.
Getting the right supply voltage for the mike is important,especially for its sensitivity calibration. Also the preamp may misbehave if the suply is too low. Using clipleads to connect a mike signal will also capture lots of emi which you don't want.
This stuff is never as simple as it looks.
I should have noticed that your output level window was set at 1 V.This indicates that you are driving your speakers for a frequency response level sweep using the control box without an amplifier,i.e. you have a series resistor added to the speaker impedance,forming a voltage divider.You will need an amplifier and a kit based on a LM3875 i.c. (or similar) would be suitable for this application.Also a precaution when testing tweeters ,is to open the 'settings' dialogue box,the yellow symbol with the two ticks (on the line ,to the right of the green start arrow) and alter the L.F. limit from the 10 Hz setting to say,500Hz. For phantom power an 18V supply can be made from two 9V batteries ,plus a switch ,but they and the wiring must be shielded from EMI and RFI.
Thank you everybody. Now i know what to do. A Clio Mic-01 will be ordered and a amp will be connected in the next measurering-round.
If anyone is interested in following the updates, you can find it on SpeakerBuilder Forum - Powered by Web Wiz Forums in the nearest future.
- Design & Build
- Equipment & Tools
- Measuring problems
