How to optimize this CFA?
I have build VSSA and then inspire by Lazy Cat who achieve 0,0001% THD at 1kHz, 1W/8Ohm with his First One, I want to modify my VSSA.
Please help me to optimize this design for lower THD and to make stable. I want to make this design as simple as possible. Any suggestion are welcome.
Anistardi
  • VSSA 2 Lateral OPS OK3.asc.pdf
It's a CFA , needs regulation /CCS's .. no way around it.
It's 2 big caps make THD .01% at 20hz. No way around that without
a servo. HF is extraordinary, PPM all the way to 100k.
Below is what I settled on for this design. It will be my second CFA
IPS. (with servo) :D
PS - make stable ???? It will run with NO compensation ...
Also , heck with the "THD fetish" , I want PSRR , no drift/DC , run cool and to last for 20 years.
.001% and below is a good target.
OS
OS
I want to trade THD 20 Hz for simplicities. Btw, my ears more sensitive at high freq :D. May be I add capacitance multiplier for IPS.
:cool::)
If the -3dB cutoff is still 5Hz.... that is too high IME. Especially for users with LP systems... W & F and rumble etc has a lot of low freq noise.
Thx-RNMarsh
How about this? The -3db is 2Hz. Is it enough? Btw, I do not have LP. I use digital player.
