My version of an Ultrasonic Record Cleaner
I don't know if anyone here is familiar with the practice, but a trick used in the US industry is to put some aluminium foil into the US bath to check functionality. You'll quickly see tiny holes or pits appearing in the foil. My idea was to glue foil onto sacrificial discs, keep it stationary in the bath and then examine the distribution of pits over the foil surface. This should give an idea of power distribution in the bath (if it works as intended).
I tried cooking foil in my scratch built US cleaner but could not see any perforations. I would be interested what results other folk with 'proper' cleaners get.
It would be good if we could devise a standard coupon test - perhaps a microscope slide with a light smear of something.
I guess it would be possible to actually measure the US energy and location with a transducer. There are graphics showing a distinct strong US beam in front of the US head (which is called a horn) so we are in familiar sonic territory. I doubt that the commercial baths contain even distribution of US sound energy. It would be interesting to see where it is concentrated (where the heads are underneath and how far it extends into the bath). I might be wrong and the bath 'boils' with it, but I suspect not.
martin
This was the worst thing. The transducers come with a short 6M stud. I wanted to get them spot welded neatly to the ss pan, but the sheet metal shop (who were making me some amp chassis') said it wasn't possible and they gas welded the studs as best they could. I found that when I tightened the transducers down they didn't make perfect contact flat with the pan bottom. The pan is too thin so tends to warp as the studs not perfectly normal. So I spread some PVA glue as a gasket between them. Most likely this is my problem. Might be better to drill and bolt thru the pan bottom. Use a Loctite type gasket sealant.
I might experiment by just holding the transducer horn just below the water surface. I was thinking of setting this up in a cup to avoid flipping the records.
The thing makes a huge din and I guess it is dissipating all its energy uselessly. Can anyone estimate what the thickness of the commercial baths is? I am sure it must be possible to make a working bath.
Transducer to tank bonding
Hi Truetone,
The mating of the transducer to the tank wall needs to be done with care and precision. It is generally done by precise brazing (not welding) or most commonly, using calibrated amounts of special high temp epoxy that can withstand severe vibration.
There is a very low probability that a first-timer can successfully complete these procedures. Experimenting with transducers and thin stainless steel tanks gets expensive quickly.
B B
Hello guys.
This is my first posting at DIY Audio ever, but I´ve been following this thread for a while.
I see that some of you have concerns about if ultrasonic cleaning can damage your vinyl.
Well, one guy here in Norway has offered one LP for testing this out in an Eumax 40khz cleaner. So far this LP has been in a bath for over 200 hours without any sign of damage or reduced sound quality.
I agree with @bbftx that 80khz might be the most optimal frequence for cleaning vinyl, but a 40khz cleaner do the job, and wont force any damage.
I choosed a Crest CP-500/D when I built my cleaner. This cleaner sweeps between 42 avd 45 khz, and cleans my vinyl as expected.
On this unit I can also adjust the power in 9 steps, and on the alu-folio test it is easy to see the difference in ultrasonic effect between the different steps. Though, cleaning vinyl - I run it on full effect.
It s a matter of safety and not depth of cleaning. Higher frequencies are just safer.
On the other hand, to my knowledge, most if not all commercial units also work on 40KHz. With significantly lower bathing times (higher rotation speeds) than those suggested in this thread though.
