Juma's LSK Preamp - SMD version
Here is BOM for stereo pair. I can purchase the BF 862 in a reel and match if interested, I haev found that when these things are purchased in qty and are in factory packaging, they tend to be fairly tightly matched. I also have the MUR 860 leftover from a previous GB, as well as some of the Vishay caps, if anyone is interested. It looks like a stereo pair of boards will be $35
  • LSK BOM.pdf
A stereo pair would be great! Also interested in getting the smd parts mounted. Also want to buy whatever other parts you are offering, matched of course!
( I just got some SMD boards to solder up, and I've got no proof if I'm up to the task or not.)
Board files
Her ya go. Give a once over for safety sake.
are the 2 pairs of jfets paralleled in the input there to allow the use of bl range devices? Couldn't we get away with one bl pair?
I have two suggestions:
Arrange input pairs to allow thermal coupling with zip tie arrangement.
Have a breakup line between the psu and line sections, this would allow to break of the psu section and use a single psu for both channels, for transformers with single secondary.
Ps: buzzforb, sent you a pm a couple of days ago, did you receive it?
