The Pass Pub: The High-End Off Topic Thread
Joined 2006
Earned a new scout achievement badge..... :D:D:D
Official Court Jester
Joined 2003
from 6moon/news :
January 2014 - Pass - Pass Labs bow their X.8 Series amplifiers to "deliver more power with fewer stages, lower distortion and less feedback". The range consists of 5 x class A models and 4 x class A/B, four stereo and five mono amps. The 2-channel amps are the X150.8, X250.8, X350.8 and XA30.8. The monos include the X600.8, XA60.8, XA100.8, XA160.8 and XA200.8. Per-channel ratings range from 30 watts for the stereo XA30.8 to 600 watts for the mono X600.8. Pass Labs increased the amplifiers' class A operation with higher power Toshiba Mosfets and many more of them than usual. The X250.8 and XA100.8 amplifiers each use 56 output transistors whilst the X350.8, X600.8, XA160.8 and XA200.8 get 72. Improved direct-coupled front ends unique to each model boast very high stability, low distortion, low noise, 100kHz open-loop bandwidths and very high input impedances. The power supplies are also larger than they were in earlier amplifiers. The X150.8, X250.8, XA30.8, XA60.8, XA100.8, X350.8 and X600.8 have one third more storage capacitance and new CRC filtering to round out the edges of the supply ripple. The power supplies still use paralleled fast/soft rectifiers and very large toroidal Plitron transformers but the AC primary circuits now incorporate additional RF filtering. The front-end circuits boast massively larger power supply decoupling and low-noise shunt regulators. Output noise was lowered by more than 10dB and the new amplifiers are much more resistant to variations in the AC power line." Pricing begins at $6'500 for the smallest XA30.8 in the 'high current' range and $6'400 for the X150.8 in the 'high voltage' series. The XA200.8 tops out at $40'000/pr for the XA.8 models whilst the X600.8 at $26'000/pr does the honors for the X.8 versions.
Your link, ZM, shows tasteful cases and heatsinks and with your experience of Papa's work, you just KNOW that they are good..........I've nothing against 'brand loyalty' by the way,
But some of the speakers really do look gross....have to admit that the Wilson Sashas look as though a real designer attended - to the outside at least.
But what turned me on was the (nearly) all singing SP-10 (or 15?) TT. [Brand loyalty I suppose!:)] But I can never understand why modifiers of these do not take the electronics outboard - doing away with that awful top-plate - and mount the motor alone in a decent plinth. That elderly Japanese guy (Kinyata?) did this many moons ago.....and I am doing the same having ousted the electronics to outboard some 12 years or more ago.;)
[Vantage Audio have my motor + PS for service and repair and I hope to have it back soon - they are excellent but they are very slow!:mad::mad:]
Yes...DD. The DD motor unit is mounted to the top-plate which you see on any normal SP-10.
The pic for the PAss display showed what I Believe is on of Mr Porter's treated plinths. The other approach is similar to Mitch Cotter's approach as shown in the second pic. His was very utilitarian with little desire to 'make it look good'; it was also suspended.
Take Cotter's idea and sink the motor down within the plinth and you get a better looking design.
The electronics are normally contained within the underside of the top-plate whereas I have mine in a separate cabinet linked by a multicore cable. Other than the motor there are no electronics within the plinth.
EDIT:
Looking at the cotter pic it seems from the various switches at the front that he has kept the electronics inside the plinth. Also, the raw power supply was always in a separate off-plinth case. What I have in mind is more like Pic 3
