Full-range speakerbox idea.
2x12" in band-pass for bass, 2x8" for mid and HF...
X-Over passive please .....
MB FR212 X-over
MB FR212 X-over
what about 2" driver crossover with protection.
Dear Apex,
I understand from your post that Mosfet Xover are better than BJT based.
I have seen two types of Mosfet Xover.
Let me know the which is better?
Or advantages of both the circuits.
Or suggest which is best for using 2" throat driver.
Dear Apex,
Use first circuit but with IRFP150 instead IRF540 for 2 inch driver.
Thanks Apex.
IRFP150 is not regular device.
If possible, kindly suggest other equivalents.
is it possible to use two devices instead of one for handling high power?
IRFP140, IRFP250...
MUR460
Mr. Mile can the diode MR854 change with MUR460 ? it is hard to find MR854 in mya local shop, i need the compression drive protector for my project ( post 61) .....Regards
X-over circuit with fast mosfet protect for horn drivers.
MUR460 will be OK
using PA Apex H900
Regards.
Thank you for fast respons sir, this CD protector will work with Apex H900 ? i use CD with 2 inch voice coil.X-over circuit with fast mosfet protect for horn drivers.
Regards.
Regards.
What's the frequency? Thanks
Estimated Mile:
Hi, I'm from Chile ATOM and would like to know if you have the possibility to send some model gia Acute wave line array to advance my project to design and build with you simplest possible materials and craft. I have carefully followed their proposals for the construction of low frequencies and boxes are very interesting.
Waiting for your response Sincerely.
ATOM
ATOM
- Live Sound
- PA Systems
- DIY PA Speakers Setup (Line Array)
