Group Buy: SSR03 Super Regulator Power Supply
Disabled Account
Joined 2012
Overall Picture of Amp playing with your board PA
The fina result::p thanks to PA
Oops... This is both + and - on same board...
I need to get the pcb's as well as the BOM.
Sent from my iPhone...
Can't edit posts...but,
What is minimum required input voltage for regulated 12V output?
I plan on replacing my 78xx and 79xx regs on my soundcard.
Wondering if I'm going to have to use a clean external PSU to power this.
Disabled Account
Joined 2012
Amps
So what is the max current capability of this PSU?
I don't need much amps. For me about 500mA is more than enough. And that's easy for the SSR03.:p
Posted the schematic. The -22 and +22V are from the SSR03. :note: I need clean input stage voltage. This is much better than the original zener witch provided the 22V on the board.
