Hi guys, im just thinking out loud here for a moment, but my first is a Q.
does a scoop play similarly to a tapped horn as far as function is concerned?
and second, can a scoop be made to play full range, and do it in a decent form?
im thinking about making a rear loaded horn, like a scoop, but with a shorter horn path to emphasise 80-200hz rage while keeping a DR type driver that will play up to 2.5khz.
thoughts?
thoughts?
not that i understand "an epic BR cab"is or what it represents but the 4520 or 4530(single 15 version) with the right(and by that i mean wider bandwidth driver) can yield excellent results well into the upper midrange but your original question was does a rear loaded horn behave like the tapped horn? i my opinion no(i'm stating opinion because while i am a knowledgeable individual i'm not an expert).
i might be wrong but in your post it seems like your thinking of using a rear loaded horn under a unity horn to what ...try and get better low mid definition punch, coverage, projection?
as an old dog eared PA guy i remember cobbling together festival pa's outta any and all boxes we could get our hands on, that meant a wide variety of different boxes to play with. i learned the hard way what combining different box designs designs could do. everything from creating massive nulls at frequencies and places you wouldn't expect to outright killing drivers in a combined "array"(translate to bric a brac of boxes)
a direct radiating rear horn loaded box with/vs a unity horn it think the sum of those two will leave wanting...(for better phase summing over distance)
this^
basically what im looking for is the most efficient cab design that will net me what im looking for as far as better kick/punch arund the 80-150hz range, but will still act like a DR style cab into the upper frequencies (300-3000)
my current cabs are Bass reflex loaded with Eminence Delta12a drivers, theyre tuned to 80hz, so they play fairly flat from 80-16000 (two way) but flat do 80 isnt good enough to keep up with my subs as far as kickbass goes.
i designed some rear loaded horns but the cabs are going to get pretty bulky pretty quickly and i do need to be able to lift them by myself. heres a couple sims and a picture of what im on about.
and this is what i had in mind for a top cab.
12inch would reside in a sealed top section and fire down and forwards with a roughly meter long horn path.
the front firing drivers would be a pair of 6inch midwoofers. and the tweeter is a Selenium D220ti
cabs im otherwise considering (all running with the Delta12)
HD15
LaScala
Cubo12
JBL scoop mentioned above
and also, then considering going full normal DR style but line array instead.
my biggest problem, i need to choose something and go with it which is why im having such an issue deciding which way to go.
heres my sim in the Lascala cab.
note: "modded from current" was my idea of shifting the front baffle backwards into the box and fitting waveguid style panels onto the front of the driver for more directivity and attempting to enhance the bass response around the 100hz mark (even tho it boosts at 200 it would blend with the subs better if they were passed at 100-120hz @12db/oct
looks like you might need a forklifter to move it ?
how about a pair of 15" below the Delta12 ?
sorry I don't understand
I thought you just said the Delta's are better mids than woofs ?
but if using medio size woofers like 12" maybe consider SPL might suffer
and from what I understand SPL is exactly what you are lacking to keep up with your TH subs ?
or maybe look at PPSL designs ?
When I set up outdoors I still havent established a "best" way for positioning everything. If I run the subs central it leaves me with no choice but to run my tops on tripods. However running my subs two per side gives me enough height that I can run my tops on top and thats where I could certainly run a bigger, heavier top no problems.
If I cant pick a distinct sound benefit then maybe I should run them for optimal setup?
what crossover frequencies are you using?
i'm not sure but do the ss15's suck running up to 200 hz i've done heretic things like running Cerwin Vega B38's as high as 500 hz.
so i guess i'm trying to determine why you can't simply raise the upper limit on your sub's?
ps in vertically stacking two ss15 are you placing openings together,apart,same side?
- Live Sound
- PA Systems
- scoop style midbass horn.
