Measuring the SPL of loudspeaker at home.
Disabled Account
Joined 2013
OK. I brought the speaker in the middle of the room. And this is the response I got!!!
attachment.php
attachment.php
attachment.php
Disabled Account
Joined 2013
Do you have level controls on the crossovers? Simply turning the tweeter down a bit could help. And titanium can have nasty breakup modes, that may be what you are hearing.
I have L-pads, and they help a bit, but not quite.
Better to control tweeter resonance Pano , damping helps but may mush up everything . i would like to see impedance magnitude , the ringing should be present here and he can control from xover ...
I heard Greg Timbres have said, coating the dome of these Ti tweeters, removes the "zing" out of them and should tame them.
See here:
https://www.google.ca/search?q=JBL+...woH4Aw&ved=0CAkQ_AUoAQ&biw=1097&bih=581&dpr=1
How can I measure the impedance magnitude?
Administrator
Joined 2004
To me the midrange looks hot and then you have some trouble around 7.5K. Wonder if that is driver or crossover related? Guess the only way to tell is now to measure the drivers solo.
Thanks for doing all the work and posting here! We'll figure out something yet. :)
Administrator
Joined 2004
Oh, one more thing. I see a lot of hard surfaces. Bare walls, fireplace, wood floor. The wood and brick can sound OK, but in combination with the bare walls may lead to a harshness you are hearing. I had to treat my walls like crazy to avoid that. Still have a little ring left.
I found this link very helpful:
A HOLM starter guide
Thanks, HOLM looks much easier to use compared to ARTA.
This is what I got from ARTA using Near-Field(LF Diffraction), Far-Field and then combine them. I see if I can get the same results with HOLM, and figure out if my ARTA's jig can be used on it.
Disabled Account
Joined 2013
I have to thank you for the help. :)
I totally agree. How do you suggest I treat the walls?
