passive radiators for midrange
Ex-Moderator R.I.P.
Joined 2005
I will look further into what a passive radiator can do.
its calculated like vented BR port
you are not using vented BR midrange, are you ?
(impedance peak, phase issue, xo problem, etc etc)
but without knowledge and experience nothing will ever work properly
even with, its difficult enough
I suggest to start with cheap drivers
and simple 'straight forward' design (if there are any)
Joined 2008
I just noticed what speakers you are using .link.. Very nice by the way..
Can I assume the mids aren't attenuated? yet they are a little quiet for the woofer. I'd use a second amp for the woofers to allow you to make up the difference in level and roll off the highs as needed with the mid.
Ex-Moderator R.I.P.
Joined 2005
ahh, sorry, I have misunderstood
sounded like a theoretical project
(thanks Allen)
but that impressive looking speaker you have there is not a 3way
or at least not in common sense
it is '3way', sure ... but basicly more like a 2way with sub woofer
btw
why say you are building a speaker ?
looks like you already have
or are you going to rebuild it ?
(its confusing not getting all info)
Tinitus and AllenB, thank you for your response'.
I will be building a second pair for the cottage.
The woofer is DSP controlled, with a 1500 watt plate amp. The midrange uses a notch to lower the bottom octave's. I found this to sound better than to put a cap in the signal path.
If I build a pair for the cottage, I can always face the woofer forward, and cross higher.
Any thoughts on the sound quality of a passive radiator system for the mids vs. my sealed version?.
Billy
Joined 2008
I can't see it sounding better than a closed box, or necessarily easier to work with, to design or to implement. Just my opinion. Anyway, since this low end is being discarded by the crossover it won't be the dominant effect, the filter will.
By the way, how do you notch the low end without source impedance or a capacitor in the signal path, do you use a current amplifier?
AllenB, yes I use a current amplifier. It is the Atma-Sphere MA-1. It has an output impedance of 2.3 Ohms.
When I was designing the speakers, I worked on the mid to tweeter filter first. Once this was finished, we listened for a few weeks. It was amazing, though I have always preferred a 2-way over a 3-way. When I started adding caps to cross to the woofer, every variation, be it in value or manufacturer, caused a loss of midrange clarity. It was at that point I thought, try a notch. I had a 12mH inductor on hand, did some calculation, and voila, it worked.
The natural roll-off of the midrange (9 liter volume), the notch, and the fact that the slope of the woofer was tweaked with the DSP (digital sound processor), made the cross from woofer to mids quite easy.
I just had a thought. Most of my store bought speakers have been ported. Maybe I only perceive there is a lightness below 500Hz. When I measure, it's about 1dB down. Would I be able to hear this slight drop?, or do I just remember the ported sound?.
Joined 2008
1dB may not seem to do much on some systems but when a system is good, it can make a fair difference. The octave below 500Hz is quite important for feeling the weight of certain sources such as voices.
It looks as if this region may be crossing the 'baffle step' though and this can complicate matters as you'd need to go through it in the time domain and at various angles to make sure what you see is what you hear.
As you get it balanced above and below 500Hz the speakers may sound a little more dull, but press on and get it right and you'll probably want to keep it that way.
By the way, have you thought about a first order shunt highpass filter?
Ex-Moderator R.I.P.
Joined 2005
btw, why can't the DSP take care of the 'missing midbass' :confused:
ahh, sorry, you only have DSP on low woofer
and use tube amps for the top
tricky stuff
adding another 5", having two in series :scratch:
and btw, tube amps can do weird things when presented to impedance variations from a passive crossover
maybe that is your real problem
or you could have phase problems around the missing frequency ... or both
Passive radiators work at low frequencies. As a speaker engineer, to be honest I cannot directly say why it wouldn't work, but a lot of intuition alarm bells ring in my mind. I have only ever seen Electro-Voice implement a vented mid-range...a passive radiator would be a whole other layer of difficulties. Plus your rolloff will be so much faster, and excursion at low frequencies uncontrolled...you'd have to totally rework your crossover. My educated guess is you will do a lot of work and suffer for not great results.
I might suggest instead a small passive shelf filter for the upper section? Like a 1-2 dB step just with a couple of resistors and a capacitor.
PR's don't do midrange. Baffle step can be addressed by
a passive filter pre power amp and is a lot more than 1dB.
In a 3 way the slope of the bass can be manipulated to
provide the BSC for the mid unit. Seems to me there
is a fair amount of waffle and no hard details here.
rgds, sreten.
no, it won't
but if the problem is too early rolloff in closed box, 'porting' might help
could be like rolling off closer to 100hz, instead of 200hz
just random number, ofcourse ;)
but I have always suggested to be very cautious porting a 2way when using subs
I don't disagree, but I can't see the relevance to good 3 way design.
Here we've got general details and no specifics, like why a notch
filter is really better than a high pass, giving an elliptic function.
Its used much more often on low pass than high pass due
to inevitable distortion issues for the high pass variant.
rgds, sreten.
Ex-Moderator R.I.P.
Joined 2005
The natural roll-off of the midrange (9 liter volume)...
with closed 9liter calculation does in fact show a very nice smooth rolloff at 100hz
:scratch: around 5liter seem to gives 1db more output around 150hz
not something I would consider for a final design
but you could still try in the one you have playing
stuffing with closed cell foam might do it
I still suspect your worst problem right now might come from a phase problem
