Since casing up my Paradise build it has never been fully hum free but this has been made noticeably more prominent since installing a recently built Aleph J into the system.When music is playing I don't notice the hum but can hear it from my listen position between tracks.It makes no difference if the earth wire from the deck is connected or not.The only thing that stops it is gripping the right output phono plug between my thumb and finger.
Any advice gratefully received.
HI M,
what grounding schema did you apply ?
Hi B;I had hoped to post pics but my camera won't charge for some reason.
In the p/s box the mains earth is connected to the chassis and a wire taken from this point to a 7 pin connector and through to the Paradise box where it is connected to the chassis.The +G- wires times 2 connect to the two Paradis pcb's. Grounding in the phono amp consist of a wire from each boards output to the chassis ground along with the deck grounding post which is connected to this point through a resistor/capacitor isolator.
Having relooked at Frans schematics and BK's posts I think? that I have misinterpreted them
Thats ok, these wires should connect at the power connector (upper righthand corner, next to the heatsink). If all else fails (see below) you may want to put two power diodes (back to back) between the mains earth and the P/S ground, nelson pass style....
IMHO the grounding in the phono amp should consist of two wires coming from the INPUT connection on the PCB (can use the second pair of input pads for that) to te grounding post, and there should be no resistor/capacitor isolator there. Rather, connect the p/s ground to that post as well, making it your star ground connection.
Let us know if that works, thanks
Hi Marra.... simple but effective... do not connect circuit minus to mains earth... leave it floating.... that will cure any hum.
Connect TT arm ground to circuit (minus) (as long as TT arm gnd is not connected to mains earth.
Mains earth should be used only for security reasons and only in the psu case and using two parallel inverted diodes.
Amplifier case should be connected to circuit minus and disconnected from mains eart.
Ricardo, with all due respect, but I tend to disagree, for the reason you cite - security. I think you are setting yourself up for a dangerous electrical accident if you have no connection to mains earth, in your entire system. (And I don't think it is a cure-all for hum problems, either).
I know that many systems do without ground, some have "accidental" grounding through one of the components of the system, etc etc - all examples for not-so-great grounding schemes, in my opinion, apart from the apparent lack of security.
One very effective way is, as you mention, the back-to-back diodes between mains-earth and system ground. And,, these should not be 1N4004's, but big, robust power diodes e.g. RURG80100 or similar, so beefy that they will survive the accident and cause fuses to blow, not the diodes.
That is what I meant... maybe I did not explain very well.... The PSU must be connected to mains earth using two diodes back to back, but the amplifier case can be left floating as the voltages there are not lethal.
TT ground should go to the amplifier case and circuit minus, and should be isolated in regards to mains earth to avoid ground loops.
Me and FdW did a good study about that and posted a good solution.
any pics of boards which used the V-Caps in the RIAA?
just wondering how you guys installed them on the board.
Hi
What do you mean with "V caps" ??? this black typs, on the back of "calvin buffer" board
Take care Werner
Nice try Werner.
But i think they ask for someone who spent a fortune
on some huge Boutique-Teflon thingies.
Now I am total confuse. but what is a "Boutique-Teflon thingies"
I think I am to old for that
Talk to you later
thingies
I'm so old, I have various of such parts collecting dust for many years.
One regrets having bought them, but a shame to just throw away.
So they lay there, as a reminder of vanity.
There was a group buy ( not authorized by me but i tolerated it ) of this stuff :
V-Cap Fluoropolymer Film Capacitors | Oil Capacitors
I heard only from one buyer that he liked it and then was.........
silence.....
silence.....
silence.....
Oooh no,
don't say that.
Not again.
They wanted it, they got it.
So what ?
(i am a little bit pleased by the idea they don't really
know where to stuff it)
Oooh no,
Jacco,
Any comment or advice?
- Analogue Source
- Paradise Builders
