EL34 PP oscillating
Hi guys,
I build two twin amplifier with EL34 PP UL with 12AX7/2SK170 cascoded.
Here is the schematic https://picasaweb.google.com/luixssj3/20Settembre2013#5925671677464979522
One amp is working correct, the other is oscillating in a strange way!
From the speaker I hear an intermittent hum like 50Hz and at the oscilloscope I found that there is a ca. 700kHz oscillation modulated by the line noise.
here is a photo of oscilloscope https://picasaweb.google.com/luixssj3/20Settembre2013#5925672339580485506
I tried everything, rising feedback capacitor, moving cables, disconnect feedback, inverting anode tap and relative connections.... nothings seems to change!!! I'm getting crazy!
can anyone help me?
I dislike the grids of the top triodes of the cascode being unbypassed.
Also try a R in series with a C and them in // to anode loads of the cascode or between anodes (Plate to plate) to decrease high frequency gain (Say, a 100K in series to a 100pF from plate to plate).
Sorry, in the schematic is not showed a 33uF bypass capacitor for the voltage divider on 12AX7 grid.
I'll try 100k+100pF from anode to anode but this is a guitar amp arrangement...
Using a 12AT7 instead of 12AX7 stop the oscillation but only if the bias of EL34 is 40mA, if I rise to 50mA oscillation appear again....
I'm starting to think I've a ground loop... but the other amp is twin!!!
1.- Grid stoppers on 12AX7s , 12AT7s and Gate stoppers on JFETs.
2.- R1 in series with C1 between cascode anodes, start with R1=RL/10, C1=100pF, Variable cap and pot isn't a bad idea.
3.- R2 in series with C2 instead of feedback loop C, start with R2=Rfbk/10, the value of C2 is critical.
4.- Inject a 10KHz square wave and optimize values, add C of about 220nf on output to verify stability.
Good luck !
most likely because the op did not state he made sure the fets match as a differential pair.
but he could see if the oscillation goes away when the ccs and fets is replaced by a 2K resistors to ground but it might be a little difficult cause of the pc board.
substitution method would be better.
