Valve Itch phono
diyAudio Chief Moderator
Joined 2002
That is just 1dB difference. As the one before.
Now to see about experimental error and changes due to gear, go to 500mV at 0 attenuation so the DMM can catch it better, let it there, then go -40dB (be sure there is no center trim button on the attenuator out of cal position). And measure again.
Joined 2009
502mV 0 attenuation, measured with -40dB attenuation
Left channel 565mV
Right channel 632mV
That is with 192mV at 0dB attenuation as signal from your Leader gen. After -40dB attenuation for Itch input signal, 255-275mV on Itch's output will mean 43dB max gain right on spec and 0.5dB max tolerance.
Do you refer to this post Salas?
Joined 2009
6H8C 1578 hole plate metal base
