Simplistic MosFET HV Shunt Regs
HF interferences are very difficult to remove, because of it propagates also by radiation. The best is to filter it, as much as possible, and as close as possible to the rectifier - preferably right after the rectifier and physically very close to it. HF LCLC is a good option.
Also, it is beneficial to consider metal shielding to the PSU, including the power inlet, the power transformer(s), the rectifier(s) and the initial filtering (both mains frequency and HF). When metal shielding is used, it may be beneficial to have HF CLC inside the shielding and another CLC, or LC, outside the shielding, adjacent to it.
In any case, for all kinds of interferences, it is much better to filter them before the SSHV2, not after it.
how many ripple add
From the power supply side - nothing, but you may find some signal scraps on the B+ line.
merlin el mago said:
I want to remove HF.
I used RC filter before the SSHV2 in other PSU and remove a lot of HF so SSHV2 don't remove all HF.
You have already made the right decision before - why you decided to change it?
When I said how many ripple adds is for the load.
What can "add ripple"?
- There could be (theoretically) "amplifying" of the power supply ripples. In case of SSHV it is not the case.
- There could be some rippling caused by changing current due to the powered circuit work. The amount of the disturbances depends on many factors and can't be estimated without simulating (modelling) the whole system.
Because in the new PSU for other project can use RC 1ohm 3uF because the SSHV2 can run with more than 1V of input ripple.
Sorry, tried to understand but failed. Maybe the native speaking people can help?
Joined 2011
My start for removing HF noice would be a small, 10 nF or so 1000 V poly or silver mica right after the rectifiers. Even more effective would be to use (C)-L-C choke input and start with the 10 nF. In practice it would act like choke input (DC=0,9xAC). Very effective also for HF
Joined 2011
In my PSUDII simulation the last RC 1 ohm 3uF just before the load increase the ripple.
Circuit is oscillating. Increase last R from 1 to 10 Ohm
But really. Trying to combine DHTRobs passive filter layout with active filtering changes the whole idea. I think you should ditch that. Putting resistance after the shunt just puts their good job in the closit. Short twisted wires directly as close to the load as possible from shunts, nothing inbetween. If HF noice/trancients is a problem, try decoupling near bridge.
Joined 2011
Sims 1 and 10 ohms for visualisations
Just change the sensing resistor to 1 Ohm now. Looks like it will push the borderline just so that may prove a good help.
Right, so got this now sorted and is working like a charm. Increased raw supply to allow output voltage increase but small drop in the CCS, changed CCS FET and added bigger heatsinks to minimise temperature drift at maximum current. To run this regulator at 85-90mA you need them clearly! Thanks for the tips
See further notes here: Adjusting the shunt regulator | Bartola Valves
cheers,
Ale
Joined 2009
Can't do it because I need B+ before SSHV2 minimum 300VDC
If I increase resistor value change the filter value
Also you reduce ripple if you increase the value of last capacitor but the same problem like resistor = value of filter will change
diyAudio Chief Moderator
Joined 2002
cheers,
Ale
Happy end then. And a nice documentation of the proper utilization moves. Congrats. :up:
