Eminence Coaxial Towers
Eminence 12cx with a smoothed throat.
that heavy Eminence is sold by TSG out in Utah - subjectively its not as loud as the discontinued 1114 Eminence coax sold by Martin Sound and neither seem quite as loud as a B&C 12PE32 in another of my Karlson 12s.
I've run the 4" coil coax with ASD1001 and lately with a Mylar B52 compression driver - even the cheap 1001 sounded very good with Fritz Wunderlich and piano. The 4" coil should take some 300 watt peak whacks.
I have bought cast frame Eminence 12 coax with magnet slug weight ranging from 54->80-109 ounces. The old 1114 with 80 ounce magnet is about 6dB hotter than a 206 and a 206 is hotter than a Tang 1772. Eminence's Beta 12LTA is sensitive but imo lacks dynamics with its wimpy motor and 0.08" overhang
Eminence 121844 Coax Woofer Free Shipping | eBay
TSG 12-1844 COAX 12” inch with 4 Inch Voice Coil
And 1 3/8” Screw on Compression Driver mounting.
Re = 5.52 ohms
Le = 1.68 mH
Qms = 9.95
Qes = .27
Qts = .27
Xmax = 4.8 mm
BL = 17.96 T*M
VC Diameter = 4 inches
Gap Height = 9.52 mm, .375"
No (Efficiency) = 2.75 97 db
Fs = 44.41 Hz
Zmax = 206.1 ohms
Mms = 57.4 g
Mmd = 50.4 g
Cms = .2239 MM/n
Rms = 1.6088 N*sec/M
Sd = 532.36 Cm2
Vd = 253.54 cc
EBP = 162.2
Magnet Weight = 109 oz.
Winding Length = 19.0 mm, .75 inches
Calculated Sensitivity = 97 db
I have a strange problem. I bought an Eminence CX-10 today. I had bought an ASD 1001 compression driver a while ago. There seems to be a problem with the threads on the CX-10 and the ASD1001. After going in a fair amount when there is about 4 mm left to go in, the ASD seems to get 'loose' and starts to wobble around seriously. So much that I cannot tighten it as it seems to be out of the threads ! What could be happening ?
The same ASD fits perfectly on their H290S ABS horn.
Any ideas ?
Cheers.
Ashok
An update on my comment about the threads on the ASD1001 and CX10. I had emailed Eminence also. I got a super fast reply !
There is a small intentional adjustment to the threads that enables mm threads to fit also. So a bit of play does take place initially but it does tighten up properly. So non US users needn't worry in case they find the same problem.
Cheers.
I removed the dust caps on my Beta10cx a while back for an experiment for an omni directional speaker. Since I already had the K tubes, I stuck them in to see how it would work.
Personally, I don't think it's worth the trouble. The existing horn works fine, even better according to the measurements, although I didn't measure them off axis.
Here are the pics of the Adire HE10.1 with dust cap removed, with the K tube inserted, and the response curves.
CD is eminence APT50, supposedly modified for the HE10.1 The crossover was designed specifically for this combo, perhaps some tweaking could improve the response with the K tube.
The K tube was made from 1" OD aluminum tube. Besides having no WAF, it poses a significant hazard protruding from the speaker.
It should be OK in a Karlson enclosure, but as I mentioned before, it doesn't seem to be an improvement over the 10cx horn.
Founder of XSA-Labs
Joined 2012
TSG 12844 Coax in Karlsonator
Re = 5.52 ohms
Le = 1.68 mH
Qms = 9.95
Qes = .27
Qts = .27
Xmax = 4.8 mm
BL = 17.96 T*M
Fs = 44.41 Hz
Zmax = 206.1 ohms
Mms = 57.4 g
Mmd = 50.4 g
Cms = .2239 MM/n
Sd = 532.36 Cm2
Vd = 253.54 cc
EBP = 162.2
Freddi,
I have been meaning to run this for you. This is a very nice driver - wow some efficiency and mosnter Bl value there. It does well in a standard Karlsonator - but may have a bit too much in 300 to 500 Hz peakiness. This of course can work in a tall stretched out Karlsonator to get deeper bass extension if you want it. The last plot shows a Karlsonator stretched in the vertical and depth by 18/12 and stretched in the width by 13/12 with an additional vent factor of 1.7x. It reaches down to 25 to 30 Hz.
X
ASD1001 vs D220Ti
Does the D220Ti sound substantially better than the ASD1001 ? I use the ASD1001 and it sounds nice but I felt it might be slightly less bright than I am used to hearing in a regular 2 way system. The crossover is also an Eminence unit designed for the CX-10 . There is an attenuator for the tweeter . But I wonder if the ( apparent !) reduction in extension is level related or due to bandwidth differences.
I guess I will have to measure the response before trying to tweak anything.
The final design would probably will be in an open baffle with supporting sealed sub. It would be an active 3 way system with stereo sub.
