- Yes, I do. It is what I have tried to explain in my previous messages. At the minimum, the level is higher than which I listen usually.[/QUOTE
Hope it will be changed before I receive mine.
Which type of output stage are you using ?
Have you open the jumps on DAC output connected to low ohm resistances ?
rredline Would be highly likely to order this together with the DAC sheild.:)[/QUOTE said:Here is an image of the shield, it is about to be completed
Quanghao, does the complete DAC come with an amanero module? I don't need the amanero as I already have one. Can you please add a DAC shield to mine, as you have not shipped yet? Thanks.
I have completed the DAC, I'm waiting for shields, a few more days it will be in my nah! I will mount it for you always!
You have USB is very good!
Hi Audiodesign,
I hope this JPG will answer to your questions. (8 x OPA627AP)- Which type of output stage are you using ?
- Have you open the jumps on DAC output connected to low ohm resistances ?
Hi Audiodesign,
yes, can use it, but need more current for shunt!
ok, i can will sen the imag to day
thanks
Hi Andrea,
I have tried the USB Amanero input with Foobar (Windows XP):
- When I turn the DAC on, the display shows "44Khz", "USB link_". "LOCK".
- Then, when I start reading with Foobar, the display always shows "95KHz" even if sample rate is 44.1 kHz or ... or 192 kHz in Foobar. The signal reaches to the amplifier in each case.
I've put all the DAC shield.
Material: Copper-Nickel-Zinc
alloy C7521
This is a gift for all of you!
it looks like this picture
Some days I'll get it, and I will send it to everyone. However, you have to pay shipping , about 5 to 10$ .
You do want it, please let me know! Thank you
1. sipo75
2. Domi_78
3. bobkojek
4. Erlend Sæterdal
5. danielkol*2
7. kmajjo * 6
alloy C7521
1. sipo75
2. Domi_78
3. bobkojek
4. Erlend Sæterdal
5. danielkol*2
7. kmajjo * 6
Hi Quanghao,
Is it possible to order/ship the DAC shield together with the new discrete output stage ?
When will the new discrete output stage be ready for shipment ?
Danny
please waite me, i need finis sent all dac!
thank
Hi Andrea,
Have you installed the Amanero driver ?
Are you using the standard Direct Streaming output mode on Foobar2000 ?
thank
Hi Quanghao,
I have the same questions as Danny. I would love to have the shield installed before shipping of my DAC.
If possible, can you also include the new discrete output stage?
I am not sure if I understand your post. Do you first send all the DACs and after that send the output stage or can you install it in the DAC, before sending?
Cảm ơn bạn rất nhiều!
Hi Quanghao,
HI!
DAC all ready.
The dac kit ready
I waited a few days shield
I send all DAC + Kit and shields for you!
So you would be waiting!
IV-The new design is in the design layout, I need time. Hope your understanding!
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
