I would be interested in this BOM too.hello gents, has anyone made a mouser shared cart with all/most of the components ?
Thx,
Thx,
In the build thread there are a couple of lists of material already. I am adding my own now, which is a Mouser shared cart if that is any help to anyone.
Thx,
Please let us know when this done and provide a link or shared name. It's a great help for those us considering the HB. Much appreciated.In the build thread there are a couple of lists of material already. I am adding my own now, which is a Mouser shared cart if that is any help to anyone.
Rick
Rick
It should be up now.
http://www.diyaudio.com/forums/soli...honey-badger-build-thread-34.html#post3545335
Any issues, and I'll try again.
Thanks Wembley. I'll go have a look.It should be up now.
If anyone wants a good review on the Honey Badger, there is an excellent one here. Post #298. The reviewer has compared it to over 40 other commercial amp designs he has owned and reviewed as well. These commercial designs cost around 1k-$5k rrp each.
Simon
Integrated Amps: An Addicts Guide. - Page 7 - Product Reviews & Personal Opinions (Moderated) - StereoNET Australia
Simon
this is what I see as #298. Not what you mentioned...
http://www.diyaudio.com/forums/solid-state/192431-diyab-amp-honey-badger-30.html#post2720360
oh ok, it's not to this thread, sorry...
I did find it on the stereoNET site, it's certainly positive!
Wembley - Please see my latest post to you in the HB build thread. Thx.It should be up now.
Rick
So, I'm reading these older posts in anticipation of building the HB - latest revision. Is there a consensus on the appropriate size traffo so as to meet the 150wpc into 8 ohms? It's been decades since I learned traffo theory, but I always thought you could go bigger VA wise without harming anything. The physical size of the traffo implies a higher current rating, not voltage. The current drawn by the amp is dependent on load which is determined by a lot of other factors - based on the design specs of the lowest (or highest depending upon how you look at it) common demoninator.Right, this is a basic dual emitter follower design. Lower impedance speakers will put a higher load on the VAS than a triple EF output stage would. Simply adding more output transistors would help, but even at +/-70Vdc the VAS will be pushed harder than intended.
The amp was designed around +/-60Vdc rails. Unless you can do the calculations, and modify the design properly yourself, you should build it as the designer intended.
I'm thinking 1 x 600VA or 700VA traffo rated at between 42-45 CT would be suitable to my 8 ohm speakers, typical listening levels, and reserve factor - for both channels. (Antek AN-6445) I might also beef up the filter caps too, to 10k, or even 16k as an adequate reserve. Can too large ever be a problem?
Rick
More VA in a transformer is fine. It just costs more.
What's 20 bucks more when you are building one amp? Not all that significant. Build 1000 and that turns into real money.
More capacitance can cause some starting inrush issues at some point, but you need to get into big numbers before you have problems. And those problems can be fixed with a soft-start circuit.
Thanks 6L6. You confirmed what I always thought. I guess the theory hasn't changed after all - after all these decades! I agree, the bigger ones do cost more. But for my 1-off builds, I buy what I need. I've had good luck with Antek just down the road in Jersey, and their build quality seems high. I was just curious what size is sufficient to deliver the stated specs for this HB build. BTW, I was planning on using a soft-start circuit anyways.More VA in a transformer is fine. It just costs more.
the usual rule applies.
VA from one times to two times the total maximum power.
For a 150W amplifier pick a transformer from 150VA to 300VA.
For two channels then 300VA to 600VA.
Can we assume this is for a class AB or will this rule work for class A as well?
I guess I figured it correctly then - albeit on the higher side. My strategy is... if you're going to build an amp like this, spend a little extra for a beefier traffo and PSU so you have the reserve when the music demands it.the usual rule applies.
Rick
#2 - Since I have 4 boards (really!! ... guys) I will make 2 "flavors" of the badger...
one bjt input and one FET!!! input.
Hey Pete,
did you already try it with FETs? I also was wondering that it could be an improvement to used matched 2SK170 (or one LSK389 in my case) for Q1/Q2 and since I'm re-doing the layout anyway to make the boards fit into my case I would give it a try. Or did you experience anything in the meantime that should prevent me from doing this?
Thanks and BR,
Holgi
The correct size transformer for a two channel 150W amplifier would be 300VA-600VA. If to be used for 4ohm speakers, 600VA would be the minimum. Since the difference in cost is negligible, at least here in the states, it would be worth bumping this up to 800VA. 1000VA is overkill. If a toroidal transformer is used, a softstart circuit will be mandatory.
42VAC-45VAC is correct.
- diyAB Amp - The "Honey Badger"
