in 38 pages still do not know if it works have not been bine.etc if I hear that still remain in the scheme Kon Electronic :: View topic - amp leco
Try to fit it in 260x112mm, it's same dimension as amp pcb for 3U.
Ok, here are the 2 Versions for optional diode.
Anyone want transformers
I have a few of these I need to offload soon. Ping me if interested.
Input 100v/110v/220v
Output: 62- 0 -62 or 69-0-69vac or +/-84vdc or +/- 99vdc
700va
Metal encapsulated
Can parallel 2 to get 1.4kVA
These are very tight tolerances. There is less than 0.1mVac difference in secondary voltage of 2 transformers.
They are pull outs form Adcom GFA-555ii's
Price negotiabe: PM me.
700va
Metal encapsulated
Nice work, caps will have better cooling on this pcb, thanks again.
Most welcome...
with vent 'holes'
and now able to lift it out, as a unit
Looks like custom built chopper
Soft Start w/ Fan Control.
Thanks that is very good idea to integrate this circuits on same pcb.
I suggest to use protect with NE555 for BA1200.
I'm currently using this protect in my amps but I don't remember if i posted this protect before.
...This is tested and working circuit, just needs to change T9 relay and should be fine for BA1200.
Thanks for taking the time to improve your pcb and porating 5w resistors.
Here's Rev1.2 using 10K/5W resistor.
great forum
PCBs very practical and useful, thanks mate, you are a great person, I am pleased to be in this forum with good and friendly people.
You need add output coil and 5W resistor, NTC connection must be change look circuit in post #394.
Got it... will revise that and make single protect.
- 1000W Simple PA Amplifier
