עז הוא על העיפרון של האבא שלי
Am I wrong about the articles? Admittedly, it's been decades since I studied Hebrew.
Translated to English, you wrote: "Goat is on my father's pencil", which is meaningless, at least it's meaningless in Hebrew.
Then why did you accuse him of such a thing? ...
Again, wrong guess.
Again, wrong guess.
Clearly, you did indeed guess wrong. You owe John an apology.
About 30 pounds too much, unfortunately.
He can handle it. He is a tough guy.
George
George
Never doubted that for a minute.
Scott
+-32,767 in 16bit (if I am not terribly wrong) is +/- one bit less, or 99.99695% DFS or –0.00027db below DFS.
Is this that serious?
And you mean that this limitation happens in the digital domain?
I have read many loose remarks here and there that DACs distort close to DFS
George
What point are you trying to make? That John doesn't listen closely to his designs? I think you're incorrect about that.
I thought John relied on other people listening closely to his designs?
se
pretty simple
Ah-Ha. (be-Ha-ve) anything's better than d.
At twice the cost of an AD1955, how good can an AK5394A be ?
(in a world of $1 DAC trouble, sounds like the economic final stage of yet another technology. OS or NOS, MC or MM/MI)
Incidentally, EDIROL that Scott mentioned, house asahi-kasei chips inside.
OS or NOS, MC or MM/MI ?
Again and again ! When will we ever learn?
George
Huh? The one is DAC, the other is ADC..
Which affordable DAC now hasn't, just as Boulder's filthy expensive music streamer does 1955A's.
(merely illustrating that it's often economics that forces a product to a halt, not the end of the technology line. => Roots supercharger/Turbo compressor)
Huh?
I'm speaking cost, you're talking alphabet.
Scott
George
CD's for verifying performance of players usually have full scale test tones on them, only recently have I seen players that don't play them without clipping, but I also see lots of spurious tones and THD that should not be there. Maybe I'll take some pictures, it's possible the rest of the circuit is at fault.
I know it's only a $100 product but the DAC in question is an Ambery that uses TI/BB parts. It was optically connected to a Toshiba DVD player playing the Denon Super Audio Check CD.
Scott, Hans did some explanation in the side bar at the end of the article specifically for figs 4 & 5. That is not what you are looking for?
jan
Insufficient information, he shows a boxcar windowed sine wave, the spectrum is continuous and not at discrete frequencies in this case the sidebar makes no sense. I hate to make assumptions but figure 5 seems show a continuous sine wave at one frequency resulting from phase re-arrangement of figure 4. Figure 5 is simply physically impossible from the information given. I fear there might be a total mis-understanding of Fourier theory which would not be a new thing.
Don't worry Joshua, I understand that you know what I am talking about. Many here, apparently do not. We have talked on the phone, as I remember, that is more than enough for me. Your continuing input on this thread is refreshing, reminding me of my 'committed' clients, rather than the critics of hi end audio.
Excellent idea- the user can always add capacitance or shunt resistance, but it's awfully difficult to reduce capacitance. And we're certainly agreed that loading is VERY critical for extracting top performance, regardless of whether you personally care about MM or not.
If feedback is not anathema, it is fairly easy to reduce capacitance over a reasonable bandwidth. In the case of JFETs for example, a stage with feedback to the source can remove most of the gate-source C. Cascoding can reduce the Miller drain-gate C, and driving that cascode part so the drain sees a replica of the gate voltage can reduce it further.
Negative input C can be generated by positive gain on one side of a capacitor connected to the input, of the right amount, again over a restricted but still useful bandwidth. This means that even excess cable capacitance can be reduced if you like. Of course this is not for the faint of heart, as regeneration is just around the corner.
I prefer the first approach for the most part, as this reduction effect translates into less capacitance variation with voltage, which is a distortion mechanism whether a linear variation or not. Of course most of the time it is also a nonlinear function of voltage, which just makes things worse.
For low Z sources like typical MC cartridges, these are usually minor concerns at midfrequencies. The behavior at well-out-of-band frequencies, the ultrasonic spuriae, and what these may do downstream, is another matter.
- Member Areas
- The Lounge
