Updating an Ellis 1801 Crossover
and there is music
my crossover build got waylaid by self inflicted damage created when I tried to install the new crossover in the speaker. Broke one of the woofer capacitors. So
1. had to order some new parts
2. decided to move the crossover outside the box
this cabinet is tight due to two large braces dividing the interior into three narrow spaces.
installed the black hole - very smooth installation, slick product
still waiting on boxes for the crossovers so have temporary arrangement of crossover mounted on a 2x6 and wires running in through rear port. Not pretty - Donna walked in and said what is that contraption on top of the speakers, and then hope its not going to stay like that!
been playing music for about 3 hours and have to say I am impressed with tweeter sound. Always found these speakers a little dark - now I have details galore and a bit brighter sound than I am used to. Not a bad bright though so far. A reminder that little was done on woofer side (blackhole 5, new wire and so far removed poly behind woofer). On tweeter side though there is new wire, changed resistors to 8/12.5 as recommended by stellablues and have new platinum bypass capacitors. Still using old connectors in my jury rig - new ones will go into the box (hopefully next week)
back to Clifford Brown
Awesome. Glad to see progress. I'm also glad to hear u went with the 8/12.5 as the other option may have made the tweeter too bright. Are u using the 1801b schematic or 1801a? I assume b. that's what I upgraded to in my post.
I have also been doing some tweaks. I didn't purchase all the platinums so I used some vishal mkp1837 in the other spots where I didn't have bypass... I can't say yet the impact but I am not hearing a negative issue either like I did with the sonically gen ii.
yes mine are "b" versions
curious that I swapped resistors and things sound brighter - I'm sure there will be a break-in time with all these new parts and materials so will not get too critical in what I am hearing til 50 hours or so. Enjoying the music though - was spinning some Lee Morgan and Bonnie Raitt last night - sounded great.
Nice thing about external crossover is the ability to tweak parts - for example would love to try some silver and gold mundorfs in this crossover. Still debating whether this is a box that sits on top of the speakers or on the floor behind the speakers - either way not aesthetically pleasing as in the speaker.
Pulling from this page:
http://www.ellisaudio.com/resistorvalueoptions.htm
1. 7, 15 (7 ohms in series and 15 ohms in parallel) - flat tweeter
2. 8, 15 (8 ohms in series and 15 ohms in parallel) - about 1db down tweeter
3. 8, 12.5(8 ohms in series and 12.5 ohms in parallel) - about 2db down tweeter
I went originally with 8/15 and it was a little bright. 8/12.5 is better for me and my room/equipment.
Absolutely wish i could play around like that as well. if you get a design for external boxes, let me know. I assume its a nice box which sits on the floor with extra wire running to the speakers with some simple connectors there? who has a good model for this out in the world.
Then the cost of the additional top shelf wire....
Aaron
That is interesting:confused: In any event, the Platinums will need around 550 hours:( However, you will be there before you know it;) If you have the coin for the Mundorf S/G, I'd recommend the Jupiter Vintage Flat Stack for that tweet.
Aaron,
I do not recommend the Platinum bypass on the low-pass shunt. The G2 is a cheap tweak that people use to warm whatever they have a G1 connected to that seems too bright. I do not like the small 1837 bypass because it generally results in too bright of a presentation more times than not.
If I had the these speakers, and the budget... I would use Jupiters for the high-pass. No bypasses. The G1 is excellent for the LP shunt. All of Dave's other selections are great. I do like better wire, but so did Dave. And, I think everyone agrees on BH5. Those Jupiters were not even available when the 1801 was offered. Even if they were, few would have dropped the coin for them.
Aaron,
The tweet calls for a 6.2 and 8.2 in series with an inductor between. Jupiters only come in 6.8 and 8 values online. What is usually done in this situation? Call Jupiter? Same question would apply for any cap type if I cannot source the exact sizes...
Just about any cap used here is going to be 5% or 10% tolerance, so I assume a 5% delta is more than acceptable. I believe the target value is not as important as a tight match from Left to Right. Say...1%
OK, we are in spec with a 5.89-6.51uF (5% tol), and a 7.79-8.61uF. I'm sure I can pull a ~8.1uF (high value) 8uF from stock. I can probably match a pair to 0.1%. That was easy. However, this will cost a bit more, but remember I said, "if you have the coin". I would parallel a 1.5uF, and a 4.7uF.
The biggest problem you will have is placing these in the cabinet. It is doable, but an external box is recommended.
Just posting an update to my crossover project.
If you read thread above you will know I damaged one of the original soniccraft capacitors in moving the crossovers to boxes. With Jeff on vacation I went elsewhere and purchased Mundorf supreme capacitors - same value as damaged cap.
The caps arrived on Tuesday. First off they are huge - like a european wiener size compared to the battery sized soniccraft gen 1's. I finished the installation of everything on Tuesday afternoon. So the wiener sized caps, the second box, new connectors, re-installed the ports, hooked everything up and it works! Small wonders...
Sound is darn good - as I write I am about 15 hours. Everything seemed to go through a funky period last night at about 4 hours. Smoothed out this morning as I put the brilliant Alexander String Quartet Shostakovich on repeat for the day. Smooth clean sound - particularly liking the highs.
Some photos - need to finish box with something that compliments speakers and room but going to listen for a while before messing with things.
Hi David
I've also got the 1801B speakers and just stumbled across this interesting thread.
Did you read Dave's comments on changing the square edge of the baffle to a 1 1/2" radius round-over?
From this thread, (1801C Discussion String), Dave comments:
"The bottom line... I will never purvey, or build a speaker with less than a 1 1/2" radius roundover in the future. If the subjective value of the Sonicap Platinum bypass capacitor implementation is $180, the subjective value of the 1 1/2" radius roundover on all edges of the baffle is $400-$500."
I think he is referring to the 1801C design but believe it also applies to the 1801B as well. Sounds promising, but it's a heap more work involved to change/build new cabinets!!
David,
It has been some time since I have posted. My apologies. However, it sound like you may have bumped into some very good resolve by accident. First, let me address your concern emailed during our down time. The leads on Sonicaps are not fragile at all. I can only guess that your XO has been man handled over time, or installed under some stress. Leads breaking just does not commonly occur. As a matter of fact, lead size and type are selected for more robustness at the expense of some sonic performance. Had I been on vacation, I probably would have been checking email and replied. I was very busy planning our future expansion, and working on our long overdue E-commerce site. Again, my apologies. By the time I had seen your email, I had also read your post above. I knew you were in a good place.
I have learned to avoid altering the advice of designers. I only do when I find their advice particularly egregious. The Platinum is an improvement, but I feel that other caps like the standard Mundorf Supreme without bypass to be better for the OW1. The OW1 is detailed and consistent, but a bit too bright for me. A Sonicap G1 would not be my first choice, but it beat the heck out of a Solen, Bennic, Erse, Dayton, etc.... If the tweeter was more laid back, then the G1 might have been the perfect go to cap.
You may also find the Platinum as a nice bypass to the Supreme.
Marcus1,
A large radius cut on the inside of the woofer mounting hole is the only way to go. This is standard practice...for me anyway. The thicker the front panel, the more it helps, and the more you can give it.
apologies for slow reply - still here and still enjoying the music. Imagine everything is mostly broken in by now. I think the upgrade has been significant - combination of new wire, caps, upgraded connectors and black hole stuffing. Can't compare to how it was before but can compare to my other speakers (which I used to prefer so much that the Ellis' sat on my work bench unused for 1+ years).
My front baffle has a round over - not significant but not sure if this is what Dave's article had in mind as I don't see any photos. My baffle is a piece of solid mahogany - but not about to start over with a router on my boxes.
I have been thinking about using the platinums as a bypass but the sonicraft caps are small with short arms and they are wanting to bypass the Mundorfs which are long and broad. A challenging coupling - guess I will need to buy some more hookup wire to extend the connectors (me and connectors haven't had best relationship as Jeff notes) to reach both ends of the mundorfs.
David,
I'm am probably the post delinquent poster of them all:eek:
I am glad to hear things are sounding good. I do not think I would take a router to those cabinets at this point either. Email me with a request for wire. I'll send you some free UPOCC in Teflon remnants. They will make for excellent extensions;)
