Primrose(SumR Audio) Toroid GB
Guys. Here is the original list. If you have added, please change you r listing. If you have paid, please mark your spot in green and add real name to right. I cannot cross reference everything as many have not included their screen name. I am pretty sure that just about everyone has sent info, but I believe we have a feew left and I need to identify who they are. I hope to place order Monday or Tuesday, depending on schedule.
https://docs.google.com/spreadsheet/ccc?key=0Av3k36EKupGAdDZmLXJfcDl5MkFVVEFDV2ZoX1Z3Vmc#gid=0
Hi Buzz
I would like to be part of this Group Buy, but it's hard follow everything in all the 18 pages and can help everyone how doesn't read all pages.
This is what I find at the new Primerose website.
Primerose Audio Website said:
Toroidal Power Transformers for audio with low flux density.
Audio Grade Transformers with electro-static screens: an electro-static screens between primary and secondary.
Audio Grade Transformers with magnetic bands: a core band around the circumference to protect surrounding circuits from any stray magnet field.
Audio Grade Transformers with epoxy center: the center epoxied and drilled for mounting.
Toroidal Transformers for audio builders.
PRIMARY CONFIGURATIONS: A SAMPLE OF PRIMARY VOLTAGES;
Single Primary: 117Vac; 120Vac; 230Vac; or 240Vac.
Dual: 115/230Vac or 120/240Vac.
Universal: (100V, 120V, 220V, 240Vac) or (100V, 115V, 230Vac).
Or a Primary to your specific requirements.
SECONDARY CONFIGURATIONS: WE BUILD TO YOUR REQUIREMENTS:
2 matching secondary outputs or a center-tapped winding.
4 equal secondary outputs.
High voltage windings for tube circuitry.
Customer specified secondary output voltages.
RESET THERMAL FUSES
Heat resettable fuses in series with primary for protection.
SHIELDING:
Electro static screen between primary and secondary.
Core band for magnetic shielding of surrounding circuits.
Fully shielded and epoxied into a toroid transformer container.
MOUNTING OPTIONS:
Standard neoprene pads and metal washer.
Epoxy centered with drill hole for mounting.
Fully encapsulated has centered bolt shaft for mounting.
Here my summarized for reading all the 18 pages.
All toroid transformer included:
-electro-static screens
-magnetic bands
-epoxy center
-Primary of your choice:
--Single Primary: 117Vac; 120Vac; 230Vac; or 240Vac
--Dual: 115/230Vac or 120/240Vac
--Universal: (100V, 120V, 220V, 240Vac) or (100V, 115V, 230Vac)
-Dual secondary of same voltage
-Mounting hardware
400VA Toroid transformer:
-65$
-Encapsulated: +29$
-Extra winding +6$
-Normal Size: 119.3mm(4.7") x 56.5mm(2.2") Weight: 3.1Kg(6.8Lbs)
-Encapsulated Size: 133.4mm(5.25") x 39.9mm(2.75") Weight: NA
600VA Toroid Transformer:
-99$
-Encapsulated: +39$
-Extra winding +6$
-Normal Size: 132.5mm(5.2") x 70.7mm(2.8") Weight: 4.8Kg(10.6Lbs)
-Encapsulated Size: 152.4mm(6.0") x 88.9mm(3.5") Weight: NA
800VA Toroid Transformer:
-105$
-Encapsulated: NA
-Extra winding +6$
-Normal Size: 148.1mm(5.8") x 69.3mm(2.7") Weight: 6.1Kg(13.6Lbs)
1000VA Toroid Transformer:
-125$
-Encapsulated: NA
-Extra winding +6$
-Normal Size: 149.3mm(5.9") x 72.4mm(2.8") Weight: 6.6Kg(14.5Lbs)
And the final questions are:
-Did I miss something or everything is accurate.
-Is it the same price for all primary winding.
-Do we have the specified the primary frequency (50/60hz)
-For a choosing secondary voltage, does they come in dual independent winding or centered tapped or both.
-Is the 6$ for extra secondary winding are for single, dual (same voltage) or centered tapped.
-Is the encapsulated can made of aluminum or metal. Some people like to built project with non-magnetic material.
I hope isn't to many questions, but I think it would help some members of what options they have.
PS. Maybe you can post a summarized in the first post to help people how doesn't read all the 18 pages and extend the group buy for a week.
PPS. Sorry for my poor English.
