#26 pre amp
Joined 2011
I dont understand why current goes up like this. Your one channel audio circuit now takes 115/8200=14 mA at plate voltage 120,5. Try half the resistor again.
Then we might have to have a more detailed look on your cathode and grid circuit. I'm gonna be on the road in a while but adjust last R until you goal which should be around 150 V, then you can set scope on the anode (scope on AC-mode) and measure your ripple. Then try a squarewave thru the circuit.
Aim a bit high on B+ voltage or adjust with both channels hot, cause your trafo is going to deliver less voltage with both channels current plugged in.
Looks good. 136V on plate, 9.59V on cathode is basically the same working point as per Andy's schem (138 and 10).
Add a second grid stopper (resistor body as close to the socket pin as possible) ad fire it up!
If online newspaper won't report as breaking news a big mushroom cloud over Catalonia in the next ten minutes, means that you can check your preamp with the oscope :D
