Enclosure's volume?
Hi there: Your drawing shows the origional front (colored red) positioned between the sides, I'm curious to know if you changed the side depth dimension to maintain the origional enclosure volume? If not, the box volume will be sightly larger than designed. Hope you will post photos of the wood finishes applied and further listening experiences. Nice project...regards, Michael
Interesting. It did not occur to me that it is a "vent" in the traditional sense.
I had assumed it is simply a termination point, and that the height and width were the critical dimensions, whereas the "depth" was a simple function of the material used.
Quick question:
Can I expect the break-in period, and corresponding performance improvement, of the Alpair 10.2 to equal that which I experienced with the EL70 drivers?
Hi C, (Guys)
Best to run-in the Alp 10 Gen.2's gently over a 200 hour period. Appreciate thats allot of time at low volumes. Reasons for doing this are:
1- The compliance of the 10's suspensions are critical. The power-train is long-throw and near linear resistance up to 7-mm of travel (1 way). So its important to gradually bed them in, thus avoiding any potential un-evenness in the elasticity profile of both suspensions.
2- The Flex Ratio of the multi-form cone becomes optimised around the 400 to 600 hours into service duration. Time spent carefully running-in (200 hours or more if you have the patience) will avoid creating memory layers in the cone's substrate and surface treatment. Hence why varied general light music (including vocals) is recommended for the running-in period. Please DON'T use ANY artificial repetitive input signal of ANY KIND. I can't stress this enough, any use of such inputs will most likely adversely alter the designed performance profile of the cone.
Patience and care will bring musical rewards.
Cheers
Mark.
Yes, I changed all panel dimensions appropriately to maintain precise interior dimensions.
I have some more photos but have not had a chance to review them...
Great build. WAF seems good. How about some more photos??? Above all: enjoy the fruits of your labor.
Thanks! Will post some more later...
Hi C, (Guys)
Cheers
Mark.
Thanks for the detailed response Mark. I have been following the break-in instructions in the PDF, and based on previous advice from Dave and Scott, and experience with my EL70 drivers.
I am wondering if you can comment any further on the comparison between break-in improvements of EL70 vs. Alpair 10.2. In other words, the improvement in sound with EL70 was nothing short of amazing, especially the bass. Can I expect the same type of improvements with the A10.2?
The reason I ask is because while I am currently blown away by the mids and highs (hence, my earlier "OMG" post) of the A10.2, I am not overly impressed by the bass response of this driver/box combo at this point. This is due in part to listening at such low levels, I suppose, however my dual EL70 microTowers have much better bass at the same levels... I find this very surprising to say the least.
Awkward Port Solution
Hey all,
As noted earlier by Scott, the result of my re-arrangement of the panel orientation resulted in both an awkward look and probable sonic differences.
Correcting both of these issues ended up bing quite simple. I removed the speaker grille cloth from the grille of an old, gutted Sansui speakers and built a frame which completes the three missing sides of the "port". I plan to stain the wood a medium-dark brown, which will match the grille.
I'll let the photos tell the rest of the story. In the final photo, you will see that the grille doesn't quite fit all the way yet, as I have the speaker cable fed through the port while I await delivery of some banana terminals.
Hey all,
Listening Notes
My concerns about bass have been reduced by the fact that I realized I have my soft-EQ set to flat for the break-in period.
In this respect, I cannot fairly compare the sound to the EL70s, which do work best with some moderate enhancement of the bass and treble.
Furthermore, I have begun to increase the volume a bit now (after about 36 hours). Not LOUD loud, but not super-quiet, either. It seems the bass is starting to open up...
Mids and treble are incredible. Imaging is considerably more impressive than EL70. The highs, especially, are much more airy than EL70 (which was expected).
The "beaming" mentioned by some others is evident, and the sweet spot is not much larger than my head.
Nicely done.
I have two questions that show my complete lack of speaker design, but i will ask anyway: 1. could the slot be moved higher?
2 Will carpet influence the sound? Should i place them on a pedestal higher up, or place some more reflective material in front of the speaker?
Nicely done.
I am not the designer, however I think the location of the slot couples the speaker with the floor, which likely has a significant effect on bass. I have seen some builds of this design which do incorporate an exremely low pedestal. The one I am thinking of waas actually higher in the front than the back, in order to angle the face of the speaker upwards toward the listener slightly. Perhaps 3/4" at the back and 1.5 inches at the front. It looks cool, but not sure of the sonic effects.
I have been contemplating something similar to integrate with my slot grille.
Very nice job. What kind of wood?
Though I've heard people complain about beaming for 45 years, there are circumstances where it is an advantage. Acoustat Model 4s are a perfect example of wonderful speakers that are exceptional beamy (boy, those needed a big room, took over half our basement!!). Beaming helps make it easier to "adjust" the amount of treble from a speaker depending on how the speaker is aimed at the listening position. Directional speakers can also help overcome room reflections.
Since I tend to listen by myself, I just adjust the speaker to my specific favorite recliner in its most comfortable position. No other listening positions needs to be considered.
Indeed. If I had real reservations about beaming, I would have gone for the Alpair 7. 80 percent of the time, the sweet spot only needs to be the size of my head because I am the only one listening.
On the other hand, my wife is becoming more and more appreciative of excellent audio and we are starting to listen together more. With the EL70 microTowers in "Castle" configuration, the sweet spot is absolutely huge compared to the Pensil 10.2, but the imaging and clarity of the Pensil 10.2 is in another league.
All it means is that the wife and I will have to snuggle closer during those Norah Jones sessions.
Oh, and the wood is high quality (grade A-B) standard 3/4" maple ply. Baltic Birch would have been a 2 week wait and well over twice as much money. I am both impateint and frugal. The rest is history.
Sade - "Ordinary Love" really opening up the bass. I take everything back abouit the bass! Solid and musical! Mid-bass especially quick!!!
Mark, the EL70 is a wonderful driver, but these Alpair 10.2 are really something that I never expected. They define "Full Range".
acoustic bass, cello and the whole gamut of Eastern European stringed instruments and percussion are these driver's wheelhouse - I had messed up a couple of times composing a discography for this post, but a short list of my favorites would include anything by:
-Michael Arnopol (Patricia Barber)
-Michael Manring (Michael Hedges)
- Stanley Clarke (Jazz in the Garden)
- Flea
-Dave Pilitch (Holly Cole)
- Esperanza Spalding
- Tal Wilkenfeld
- Brian Hughes / Hugh Marsh / Caroline Lavelle ( actually the entire Loreena Mckennitt band on Nights from Alhambra)
- Brian Bromberg
- Sting
oh, there's more, but coffee break's over
Thanks cogi for reminding me why we do this
edit:
ps my son plays bass in a little independent group, so I've been paying renewed attention to it
Nicely done.
short answers
1) no
2) not much / no
- Flea
- Tal Wilkenfeld
- Brian Bromberg
- Sting
edit:
Chris,
Thanks so much for the list. Very much appreciated!
My playlist on the weekend included some cello and plenty of acoustic jazz bass and I completely agree. Haden & Metheny's "Beyond the Missouri Sky" was particularly tingle-inducing, and then during the solo cello stuff I was listening to I could not only hear the performer breathing, but I could literally hear his movements. It was as close to live as I have ever heard.
Speaking of "live", played some Eric Clapton live and Nirvana live and was transported to the venues. I have had this experience with the EL70s, but not to this extent.
Vocals, both male and female, are also incredible. So much more forward or "3D" than EL70.
The difference between properly mastered, high dynamic range music and "the other stuff" is just that much more apparent now.
Looks like I will be making even better use of DR Database
Mary Jess wants me to increase volume. I comply.
Wow. I've never heard her quite like this...
How many times can one think, "now this is "it" "?
Please. This is a family-oriented site, not one that needs direction in how to make a family.
As noted in another thread, I have discovered what I think is a null in the bass of my Pensil 10.2s.
I am going to run some frequency response analysis sweeps to confirm it, but suffice it to say that the bass line in U2's song "One" is just all wrong. It is as if Adam is simply not playing some of the notes.
Anyone else with Pensil 10.2s have a similar issue, or is this unique to mine (or my room) ?
- More Vendors...
- Planet 10 hifi
- Pensil 10.2 Build (Yet Another)
