Hi David,
Full Music 300B can directly replace WE300B on 300B tube amp, but the electrical characteristics between the two are not same.
Thanks,
Tony.
Thanks,
Tony.
Tony ,
I have a pair of WE300B in my bottlehead parafeed amps and like to roll a few other types, can you confirm the electrical characteristics are the same as the Western electric's?
David
New 300B single end with separated power supply were built. 6SN7-300B with double C-core output transformers and the power supply was separated from 6SN7, 300B tubes and output section. The tube rectification is 2x5U4G. The sound is silky and detailed.
Hello,
We don't make 300B parallel mono block amps at the moment.
Thanks,
Tony
Thanks,
Tony
Hi Tony
Do you make 300B parallel mono block?
Hi Blake,
Yes, I offer stereo SE 300B integrated amp. This is a new 6SN7-300B SE integrated amp with 5U4G rectifier. A fine quality ebony wood chassis was used on the amp. The circuit is well-designed to high end sound performance. All the transformers were hand-made by the experienced engineer who soldered and made this amp. I would like to promote this 300B SE amp in my forum and the selling price is USD1580+ shipping cost. The price include Psvane 300B, vintage RCA 6SN7GT and vintage RCA 5U4G.
Thanks,
Tony.
Thanks,
Tony.
Tony,
Do you offer a stereo SE 300B Integrated Amp? If so can you tell us the price and post photos?
The wood cabinet really makes it look so much better.
Blake
Hello,
There is only one input on this amp. It is direct signal and no input switch or selector needed.
Thanks,
Tony.
Thanks,
Tony.
Tony,
Your SE 300B integrated amp looks very nice. How many inputs does it have?
- More Vendors...
- Twin Audio
- New 300B single end
