Hi Quanghao,
Raw filter with 10x470uf caps on the DAC base still Oscon caps for this group buy?
YES!
31. 1x Ridsaudio DAC BaseCan I add myself to the list? or I'm too late?
1. 1 x audiodesign ( DAC base )
2. 1 x quanghao ( DAC base + DAC chassis + transfomer)
3. 1 x fansipan ( DAC base + DAC chassis + transfomer)
4. 1 x yildiray ( DAC base + I/V opamp)
5. 1 x danny_66 ( DAC base + I/V opamp)
6. 1 x MihajloTM ( DAC base + I/V opamp)
7. 1 x i2k92 ( DAC base + I/V opamp)
8. 1 x axeexa ( DAC base + I/V opamp + OP + tranfomer)
9. 1 x sipo75 ( DAC base + I/V opamp)
10. 1x Jinkslynx ( DAC base + I/V opamp + OP + tranfomer + chassis)
12. 1 x smoothquark ( DAC base + I/V opamp + OP +/-transformer +/-chassis)
13. 1 x CeeVee ( DAC base)
14.1x Smthgbrrd (DAC base + I/V opamp + OP + transformer )
15. 1 x larslang (DAC base + DAC chassis + transformer)
16. 1 x linuxfan ( DAC base + DAC chassis + transfomer)
17. 1 x randytsuch (DAC base)
18. 1 x claudio52 (DAC base + I/V opamp + OP + DAC chassis + trasformer).
19, 20. 2 x danielkol (DAC base)
21. NicMac (DAC base)
22. 1 x gjorgji (DAC base + I/V opamp + transformer + chassis)
23. myfavoritething (DAC base+ I/V op + OP +chassis + transformer)
24. MattMax (DAC base+ I/V op + OP +chassis + transformer)
25. bertchai (DAC base + I/V op + chassis)
26. kimgiin (DAC Base)
27. misterrogers (DAC Base)
28. malarkey (DAC Base)
29. TarnishedEars (DAC base + I/V opamp + DAC chassis)
30. Boxi80 (DAC base + I/V opamp + OP + transformer)
Fixed the list. Guys, think about it. If you don't copy and append to the whole list, how can this work?
32. meintan (DAC base + I/V opamp +OP + chassis)
I would like to close the list register here.
I prepare the ingredients for the production plan!
Sincerely thank you!
It is possible to include just one more?
I want DAC base + I/V opamp kit.
33. inforsit (DAC base + I/V opamp + DAC chassis + trasformer).
If possible.
If possible.
33. Luizl (DAC base + I/V opamp).
34. inforsit (DAC base + I/V opamp + DAC chassis + trasformer).
Ok?
Ok?
Ok?
yes! Ok
thanks
35. xtomm (DAC base + I/V opamp)
Rounded ...
OK?
Rounded ...
OK?
36. 1 x kgkim (DAC base)
Can i join this project?
I think that if you mount the transformers in an external box that there should be plenty of room. At least that's my plan.I'm also interested in joining the party but the estimated shipping costs are excessive.
Also it doesn't appear that the chassis will accommodate the tube output stage and its power supply as shown on Andrea's website.
No, at 35, spot 11 is empty.We're at 36
The difference between 20 and 35 is not that big, if you look at mouser, digikey, the pricecuts only start at 50 and 100.
We're at 36 from initially minimum 20 participants, so I think it is fair now to have cost reduction due to bigger volume involved. I'm sure everyone will agree
Quanghao / Andrea, any comments ?
The answer: (slightly) lower cost = (slightly) higher profit
The real profit will only come if Quanghao can convince the community that this is significantly better than the similar Buffalo from TPA.
I don't really think in terms of sound quality this will be a lot better than TPA, but is certainly a more complete package ( All P/S, I/V op, chassis, 4 inputs + remote display, etc)
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
