Thanks, working on a couple preamps now.
Whatcha building? I need a pre to drive my DCPP, but can't decide what to build.
jeff
Cassiel
I quite like your amp. One of the more original and attractive adds to the gallery.
Thanks. Original it is. Attractive depending on who's looking. I like it too.
jeff
I have been running a aikido octal with 6sn7gt's @ 17ma per section with good results, this Chinese slp-90 I just built sounds great pushing the dcpp, But im building a marantz clone to test also.
Ok, thanks for the update.
jeff
pitures for posterity...
Dear Tony, Your creations are in the heaven for the posterity.
They are exactly the same I like to get for my system. Color, valves and topology.
Cassiel, I like your amps, too. Unique woodwork, use of the toothed gear. The recessed tubes with the clear end treatment is a great idea now that I have young granddaughters, too -- not easy to touch, yet visible to a taller person.
Thanks for taking the risk on the artful design. I hope to try some unusual and artful work as well. You're an inspiration.
--Jeff
--Jeff
those are dapper grey ones....they may look the same but used different set of tubes and not one are identical as far as tube complement goes...
--Jeff
Wow, those are very nice words. I wanted to do something not yet seen, something beautiful and at the same time practical - your words describe it very well.
The design took me a lot of thinking, so I'm glad someone may benefit from it.
Where do I put this?
Vanity Amp - Designed for WAF!!!
thanks, i was amazed by the sound this 3 watter can dish out....
Most of my amps range from 2.5W to 5.8W but I'm about to make an 171-A amp of 0.5W. Wish me luck.
good kuck...
- Tubes / Valves
- Photo Gallery
