My suppliers don't stock 70 volt zener diodes but they do stock the NZX36, 1N5258, and 1N4753, all of which are 36 volt zeners. So you could build zener regulated, capacitance multipled supplies using MJE340 / MJE350 as series pass regulators. 6 components per rail.
if you have two secondaries, you can use a positive chip regulator "upside down" as it were, to regulate the voltage between the ground and the negative. you must form the ground point after both regs, not before
also, you can use a lower voltage regulator and attach zeners to the adjust to take it up, so long as the drop between Vin and Vout doesn't exceed spec, and you don't short the output by accident
do you have an example schematic for your first suggestion?
If you're using a 3-terminal regulator, just using a sufficiently large resistor on the Adj pin could work. Take a look at the application notes; there's a wealth of information there on power supply design.
Alternatively, this might be a case where shunt regulation makes sense. I have a hunch that could be electrically quieter than using a zener. I assume that a microphone needs very quiet supply rails.
protection diodes, caps, resistor values, should all be as datasheet
I have always wonderd about the PSRR of a mic, and can never find any info. Luckily the standard 48V phantom power is easily regulated with a LM317HVIf you're using a 3-terminal regulator, just using a sufficiently large resistor on the Adj pin could work. Take a look at the application notes; there's a wealth of information there on power supply design.
You will be dissipating a LOT of energy to get 5v out of that. I would use a winding that is closer to your intended output voltage.
well my plan was to use a voltage quadrupler to get the 70v.
Could this just be a case of tweaking resister values?
Yes. the reg's ref voltage is usually listed as 1.2 to 1.3V. So potentially up to 8% difference between any 2 units. So tweak resistors to compensate.
You can use the "2 Transistor Regulator" from Jones "Valve Amplifiers" -- the output voltage will be ~2x the value of the reference. It's good to around 40-50mA and very simple to implement.
For more current use a Darlington transistor as the pass element.
- Power Supplies
- Suggestions on regulating -70v
