Frontloaded bas horn. lowcost. beyma sm115n
2pi halfspace. 103dB 1Wmtr
Inside size 40X50X120cm.
Eminence kappapro15A wow what a great 15"!
2pi halfspace very lineair and 105dB 1Wmtr
1pi 109dB/1Wmtr
http://www.eminence.com/pdf/Kappa_Pro_15A.pdf
1pi 109dB/1Wmtr
that sure is a mighty big midrange
try this one
http://www.faitalpro.com/products/files/12FH520/8/12FH520_datasheet_8.pdf
or this
http://www.faitalpro.com/products/files/12HP1010/8/12HP1010_datasheet_8.pdf
try this one
or this
To reduce volume of the box here with short midrange horn on the eminence kappapro15A.
system volume 124liter.
Spl for 2pi and second 1pi.
the kappapro is a nice driver to play with in simulation, now made a simple conical horn on it with bas-reflex loading.
to make some thing like these.
SPL output for 2pi and 1pi placement 1pi. And reasonable size 128 liter 4,5 cubic feet.
Combined response port next to horn mouth.
why vented BR if it still needs a sub ?
To increase efficiency and bandwith. 105 dB 1wmtr 1 driver is very nice. 20% efficiency if i am not mistaken. A hifi speaker can not even make a 0,5% efficiency.
It wil make a perfect high efficient 2 way with a midhigh horn 500Hz-20kHz where time alignment is right.
It is not to bulky big can look very good with a tractrix horn on top.
Now only a tapped sub horn is needed.
I believe I already showed that solution.wouldn't closed/apperiodic make integration with a sub easier ?
a nice 10" of PHL-audio.
It's a shame PHL never publish any graphs of their drivers. I mean, look at their datasheets layout they even have an empty place for the graph but they dont publish !
I think they have lost many DIYers buying their drivers because of this.
- Elias
- Elias
Your right elias.
Looks like a crystal filter rather than something I would like to use for audio
PHL drivers.
nice, but at a cost
wasnt it his intention to use very small amps, or even small tube amps ?
efficiency and sensitivity is ofcourse nice for small amps
but how much do you really need
in any case, if the goal is high SPL and playing very loud I see no point in using small amps
so I would say for the smaller amps a more 'moderate' SPL ought to be ok
or in short
even a big high efficient speaker system can still be a heavy load for a small tube amp, right ?
filter it 4 order 1khz or 1,5khz, no higher harmonics due its own bandpass behavior.
nice, but at a cost
or in short
Why do you think that?
try this one
Looks like very well behaving driver above 1kHz (if the spec is to trust)
- Elias
- Design: Horn High Sensitivity Speakers
