If you happen to know what resistor got ya down to the 3VDC let me know.
It is not the voltage you take down, you limit the current to the diodes spec
Best regards
Staffan
Further to my trials with Russian caps...
I have just replaced the kit Wimas with 0.2uF FT3 teflon ones...
The results are .... are.... a....
OH MY GOD.... Seriously, if you are considering upgrades, this one is a major one... The change was similar to that of hotrodding towards the upper limit. Instruments are now much more focused and the stage depth is better defined. I also noticed some improvement in bass and highs but I cannot verify that for sure since it s late here so I can t listen to proper gut kicking volumes.
Kinda makes you wonder how better they can get after they properly break in...
With the 0,47uF coupling cap I used no referencing resistor and had no problems.
But after I have changed them with 2.2uF, I ve been having some bigish DC thumps when switching the amp off.
What I was wondering is if there is any rule on the value of the referencing resistor and how this could effect the sound.
At the moment the biggest value I have is 100k, but in some instances I have seen from 2k to 10k, while earlier in this thread Nikos talked about an 1M one.
Don't use less than double your amp's input resistor in general.
Ah cr@p....
Its down to specific cap leakage and value also. Don't use less than double your amp's input resistor in general.
I have no nice quality resistor at over 500K so I won t solder anything to the terminals yet.
However, my source selector is a make before break switch with a middle position were both inputs are connected.
Would it be ok if I soldered some cheap 1M resistors to some spare RCA plugs and plug these to the second source in.
I would listen music without these in the circuit, and right before I switched off the amp I would switch it to the middle position to put the resistor in parallel with the amp.
Do you see any problem with this as a temporary measure?
That resistor is to discharge a coupling capacitor's small charge build up. It should be connected to its output side permanently. A thump can also be the DC amp closing lower in frequency with the preamp now with 4 times+ the previous value and having a higher transient for its input differential amp and input base currents. So if it proves its not the caps, you may try a mute switch to ground is better because just switching the output to null signal position will surely do some other contact click noise and its also introducing a moving connection in your signal path. Not a very good addition.
Hello,
I recently finished an F5 and was so amazed by its quality that I jumped right into building a DCB1. I am planning on "hotrodding" with 10R resistors to start. I have bought large enough heatsinks to withstand more heat (i think) if i decide to take it to the next level. Anyway, I built my F5 with top quality components and I am doing the same with this build. I am still waiting on a couple of parts in the mail. I haven't made up my mind on a chassis yet.. I am also trying to decide on a transformer. I got a quote on a SumR toroid (80VA, 2X15V). I believe I will buy one of these but am still searching for alternatives. Since the fire at Antek I have had to do some research on quality toroids. I have also found an R-Core that is a fraction of the price. Any suggestions on this decision would be nice.
My main question is about my heatsink configuration. Can i mount the heatsinks with the fins facing downward (toward the bottom plate of chassis). It seems (because heat rises) that this might not be beneficial. I posted a photo of what I am considering.
I splurged and bought a 10K Khozmo 48 step attenuator. I have never had a nice volume control in my signal path so i am excited to see what it can offer. I have been inspired by the Lightspeed (or "Lighter Note") LDR volume control and may build a stand-alone unit in the near future.
I am planning on running AC mains through a Schaffner EMI line filter (FN2070-3-06). I originally bought it for the F5 but decided against it.
I just got my 2SK170BL's in the mail (Thanks Spencer). I was very diligent when matching the LEDS. They were already very close but they are spot on now.
Any comments/suggestions would be nice. Especially about my heatsink configuration and any ideas on a transformer. If anyone has any experience with SumR and can relate their toroids to Antek, that would be great. Antek says they will have their full stock back in mid-April but I do not want to wait that long.
Anyway, thanks for the inspiration on both of these builds. I have only been "tinkering" for about a year but it has been an amazing hobby. I knew absolutely ZERO about anything to do with electrical work of any kind. I have a TON more to learn..
Thanks in advance,
Madison (Tennessee, USA)
Thanks in advance,
Don't know about the transformers but do get 4 FT-1 0.022uF CCCP Teflon Ebay caps to bypass the Wimas at their pads under board and see if you like it after you had listened with only the Wimas for a while. Use some tape around the FT-1s not to short PCB something on their metallic can. Use 1 per red Wima. Since you aspire to top components assortment some Teflon may suit your taste in the mix or not. Those suggested are dirt cheap to test anyway.
Thanks for the quick reply. I was waiting to hear back so I can tap the sinks accordingly. I will face the sink downward for now. I doubt I will go any lower than 4.7R anyway. I can always adjust if i decide to...
Thanks for the advice of the teflon caps. I will order some.. Have the Wima's (MKP10) been frowned upon in this build? I discovered the Wima "Black Box" film caps after I bought these. Can't seem to find much information on them. Do you have any experience with them. They seem to be Wima's top of the line. Thanks for the advice and i will be keeping everyone updated as i gain progress.
Madison
Madison
The red Wimas in the particular type and value came out best in a mini survey we run among some users in the past to recommend in the BOM. Best among proven and widely available industrial options in manageable sizes and prices though. Having an ultra pot you may be interested in some Teflon mix was my drift. About the black box Wima I have no direct comparison experience to convey.
The SumR transformers are excellent as are the Anteks. Many here are happy with the Anteks. SumR is local to me and Antek shipping to Canada is expensive, so I asked for a quote. I was surprised to find that they were significantly more expensive that Antek (about double IIRC). When I asked what the advantage was, they never replied. Several people have bought the Rcore found on eBay and are happy. In theory, an Rcore is the ultimate, but many are wary of Chinese product.
The Lighter Note is a great product at a great price. Several on this forum have used them successfully with a DCB1. Keep in mind that an LDR attenuator is sensitive to heat so you want to arrange and plan your enclosure and layout accordingly. There was a recent discussion of this on the Lightspeed forum.
Very nice looking build so far. Thanks for sharing.
- Analog Line Level
- Salas hotrodded blue DCB1 build
