Nice toy, i have made one alike few years ago
My daugther still use it playing guitar.
35 watts RMS at 8 ohms..... aprox. ... and almost 20W at 8 ohms.
Sounds good... stérile as chip amplifiers...but it is compact and simple.
I really do not remember if i have made modifications.... this is simulator..sometime real life we have to adjust something..for instance, the zener current not to overheat.... these details.
Nice toy to build in a weekend.
regards,
Carlos
regards,
Carlos
I think you must have made something else, because this amp, as is, is terrible.
It has +/-35V rails but the Op Amp can not swing more than 12V peak each way.
You are wasting 20V each side.
It's also overbiased and not compensated, so it will self destroy thermally.
Plus other small details.
if its the original 741 op amp, this is not suitable for audio, there are much better ones, for little money. Makes one wonder how any designer could use a 741 for audio these days.
Can't see how its a nice sound, have you listened to it?
The advantage of a 741 is that can be swapped by a 5534 that will greatly improve the sound audibly speaking , i guess
that the eventual customer will at least experiment a valuable
and encouraging upgrade that will actualy work.
The nice sound may come from the complete amp or topology, not from the opamp used. CFP amps tend to sound nice, and they are not so stable. You cannot drive an existing CFP with the fastest opamp hoping to get improvement.
Indeed, there is a classic CFP design using a very slow uA741, and it sounds nice. Well, why not show me your favorite simple CFP driven by 5534 or better opamp?
I ve got something using a 5534 and either a double EF or CFP ,
i ll propose the schematic in a relevant thread if you are interested
by an original design that isnt used by any other op amp based amplifier.
Yes, yes, I'm interested with the CFP one.
Please mention if it has been tested in real life. If not, I will still try it anyway.
Well, YOU say so.Detex Audio 741 ic based low component count NICE SOUND
warm regards
andrew lebon
No schematic, just a picture.
No specs, no PCB, ZERO info.
Do we have to take your WORD for it? Why?
Agree. No way to confirm what Andrew Lebon says.if its the original 741 op amp, this is not suitable for audio, there are much better ones, for little money. Makes one wonder how any designer could use a 741 for audio these days.
Yes, pictures don't lie.pictures dont LIE hottest selling kit now
You are showing another kit, not the one we are talking about.
So, who's lying?
So we are talking about a "simple" amplifier with 2 ( two) output transistors, and you show a 24 output transistor, fan cooled example?Trying to finish 2sc5200 version with enitter resistors
warm regards
andrew lebon
Tell me this is a joke.
Of course he will, he's trying to sell themDear andrewlobon,
Are the range of Detex Audio products available in India? Can you provide an address or Tel No?
--gannaji
How do you know?Yup, this topology amplifier needs that speaker protector
We have not seen a schematic yet
I guess you are right.Andy are you part time salesman of Detex ?
The version i have has a double EF but a CFP is adaptable
and this should lower THD 1Khz to a few ppm at 10W ,
i do some sims and redraw a clean schematic for the purpose
and post it in a relevant thread.
Notice , that is low power since the 5534 will limit the max
supply voltage such that power output is barely 15W/8R but
with very low THD.
You are right.Notice , that is low power since the 5534 will limit the max supply voltage such that power output is barely 15W/8R but
with very low THD.
That's exactly the design concept error I pointed at in the schematic shown in post #5 .
The output can't swing more than what the Op Amp can (in fact, even a couple volts less each way) and the Op Amp itself is limited to around +/-15V .
So no use for a +/-35V supply.
Actualy the output can swing the full voltage provided the output stage
is a CFP with a gain of about 2 to 3 , i ll propose the option in the 5534
based amp , although i m not a fan of these kind of topology but i got it
to work in the simulator at the expense of a little more THD given the output
stage is less linear if it has voltage gain.
How do you know?
Oh my. Can't you read the schematic from the PCB picture in the first post??
Anyone familiar with amplifiers topology will be able to read quickly because in amplifier topology there is nothing new (under the sun).
Yes please!
- SIMPLE AMP
