Pictures of your diy Pass amplifier
Hoping to build a B1 buffer next but I was wondering if anyone knows,
A) What is the input sensitivity of the A40 for full output,
B) Can the amps run with approx +/- 40V rails (my transformer secondaries are 25V and I have replaced the JFET with 2N4392,
C) Could the output stage bias be increased to 2 amps. My speakers are 4 ohms and the A40 will move into class AB at 20 watts into this load.
Earthloop, it's great to see a new a40 build! This was my first amp project - mainly due to the PDF that was available at the PassDIY website when I started. Most of my efforts for the a40 are documented here.
I can make a stab at some of your questions. I do recall measuring input sensitivity for the a40 at some point, but I cannot find where I made my notes. I tend to recall it take about 1.8v to hit full output. I have a clear memory of getting 52w into both a 4-ohm and 8-ohm resistive dummy loads.
As for increasing rail voltage, the only problem that I can see (and maybe I'm missing something) is that the 2N5248 FET is limited to 30v. Replacing this with higher rated part should prevent problems. I don't really see this as a problem for you, though. Your transformer has 25v secondaries, so you should only see rail voltage of about 35v. My transformer has 24v secondaries and I get ~32v rails...
Output bias can be adjusted as well. See the table at the bottom of my a40 page. I experimented with several values for R11 and the resulting bias level. I remember Nelson stating somewhere that the bipolar output devices are most linear and sound better when their bias is kept below 1.0A each. My amp is biased at about 3.2A per channel, so each output transistor runs at about 0.8A bias.
Overall, my A40 runs on 32v rails, 3.2A bias per channel, and produces a pinch more than 50w of output. The input sensitivity is greater than my Aleph-X amps and the a40 can comfortably drive my power hungry Avro speakers to satisfying levels in a large room. I think you'll be happy with yours when it is completed!
Eric
It's been a fun and funny morning, but I would also welcome some candid comments about the cooling technique itself. I'm going to play through at least to the next phase, but all comments both pro and con are welcomed and encouraged.
If this thread isn't exactly the proper place for the topic a new one could be started if there is any interest.
ACA mostly done
ACA mostly build from spares lying around.
Works on 22V regulated Rails. Sounds realy nice for 5 Watt.:D
F5 turbo, with modular output stage (V1, V2).
www.hifisonix.com
Joined 2003
I have been requested by PM to post another one.
Patrick
I am just browsing through the Pass labs forum. Some fantastic stuff here.
This one is stunning Patrick. What have you got the bias set at?
The case work . . . wow, what can I say. Did you do the machining yourself or get it done by a professional company?
Kudos!
Thank you. :)
1.3A per FET.
> Did you do the machining yourself ?
This particular one yes, most of it by hand milling.
The front panels and the Speaker terminals were done by CNC.
And I wrote the G-Code myself.
The F5X cases are now done by our own factory.
Cannot do all 30 sets myself by hand .....
Patrick
