Foam Core Board Speaker Enclosures?
I guess it's time for me to sleep, made a mistake in the previous calculation, resultant fh should be 1233Hz.
How bout this for a change?
Tapering the end to close, and making the horn port(mouth?) wider.
Based on the dimensions of 21" x 13" x 3"(deep)
fh = (342m/s * 0.00464m^2) / (2 * 3.142 * 0.00034^3) = 743Hz
hmmm, doesn't seem to work, any suggestions?
Argh... hate the calculations. Guess I will just make a prototype and listen from there.
Founder of XSA-Labs
Joined 2012
Ravener,
According to your drawing in post 1162, the compression chamber would be approximated by a circular chamber of 3.6 in in diam by 3 in deep = 0.50 liters. The throat area I am guessing is about 1.75 in across x 3 in deep = 34 cm^2. (You have a throat that goes to nowhere, which I mistakenly thought led to an output).
So fh = (342 m/s * 0.0034 m^2)/(6.284 * 0.0005 m^3) = 370 Hz.
370 Hz is a little on the high side and it means that lots of mid-range will come out of horns and cause phase delay problems with your ears and ruin spatial imaging. You can fix this by expanding the driver chamber volume by adding a sub chamber beneath the main horn connected with a hole, or add raised (hollow) suprabaffle above where you mount driver to boost volume. Alternatively, the easiest fix is to simply clamp down on the throat area by a factor of 0.75x - put a constrictor plate there (1.3 in wide gap). The horn expansion you have is good - it will result in quite a bit of gain in the bass notes. The mouth area/throat area looks approximately 10:1 - so not bad.
IG,
You beat me to it. Nice work :) I have been thinking about doing a front horn but in 8 segments and curving it. I have been looking at Tractrix profiles and such but haven't gotten to the point of cutting foam yet. I made a mock up in plain paper just to see if the segments bend and curve the way I intended.
How does it sound?
Not too bad. The small BLH counters baffle-step pretty well and upper-bass is even hot enough on certain material that I wanted to try a small front horn to lift midrange a bit. I just threw it together with no calculations, came out ~40°, a bit too aggressive, did not have enough foamcore left to make a larger mouth. Gives ~6dB of gain from 400Hz to 4kHz, with some peaking on both ends of the BW. Also had to add a super-tweeter because it killed upper treble output.
IG
IG,
6 dB is not too bad. Too bad it impacts the high bandwidth. With properly designed curved horn, can that impact be reduced? Something like tractrix shape is used on HF correct?
FF85WK does not have the motor strength or rising response to be behind such an aggressive horn. 90° would be better, maybe parabolic could be interesting, though much hard to to make. Tractrix does get more HF out from a compression driver, don't know how it would do for a cone driver. I should look up Bruce Edgar's old article that was for a 5" JLB midrange IIRC.
IG
Tweaked the design a little, made the compression chamber rounder and the throat tighter.
fh = (342 x 0.00194m^2) / (2 * 3.142 * 0.00050m^3) = 210Hz
Seems rather reasonable...
Shall be starting work using this.
edit: upon looking at tractrix horns... mine seemed like an asymmetric curved tractrix...
