I have one of these M&K amps, as well as a Parts Express 300-794 amp, and they appear to be the same. Here is a schematic for a 250W PE amp, although I'm not sure this is the same as above.....
Edit: To add to the confusion, the PE amp box says P/N 300-796.....here are a few pics of the PE amp.
I would say it is a perfect match boywonder.
And now: Schematics in readable format?
Looking close, the M&K PCB above is quite different, with a number of multi-legged critters on this of the board.
That's all I've got for a schemo, and I'm only half sure that's its for these amps. It's a PDF, so if you want, I can email it and you can enlarge.
Its basically the same thing minus the 220v switch. I have exhausted my search for a schematic. I guess ex- M&K is wanting me to throw it in the garbage. Even his repair services had nothing. I sent an Email.
WOW, I am tired of throwing things out. I can buy a 30 year old Hafler and get all the info I need, Plus rebuild it with new boards if I want. Something to think about. CHINA!
- M&K 250w Sub amp awaken issues
