UCD 25 watts to 1200 watts using 2 mosfets
IRS-1500 Fail !
Hi guys..
so I've just finished IRS1500..but there is also a problem :(
please watch this video :
Class-D IRSD1K5 - No & Low Level input Problem - YouTube
when i turn on power supply..after s short delay , speaker connected to amp's out. as you can hear in video , there is a noise available at output. (input volume = 0) and when i increase volume up to 4~5%, a really bad audio signal become appear. also the active led indicator isn't bright constantly.
when i increase the volume (about 7~8 %) the amp start to oscillate and those problem solved.
guys please help me. anyone have similar problems ?
IRSound
Hi guys..
IRSound
post pcb picture in high definition to see what his mistake was.
Hi Jcoelhogsia,
Thanks for helping me..:)
this list shows the difference between my component and attached layout :
- Using BYV28-600 instead of MUR160 (beside IR2110)
- Using MUR460 instead of MUR160 after inductor
- Using 1N5819 instead of 4148 (mosfet's gate)
- Using IRFP250N instead of FDA69N25
- Using 47.5 Ohm gate resistor
and i have problem with no input signal and lower level input , like what you see in that video.
IRSound
Hi Jcoelhogsia,
IRSound
post the other side of the pcb.
Thanks ,
This MUR160 ?
supply voltage is about +/-55v
- also i replace those 6.8K with 5.6K.
Yes, i saw that video before. also video for 4K5 (what is the song in that video ?)
you don't have any problem in lower input signal at startup ? that blue led is light up at first ?
ja gave defect in assembling yes!
trails off!
Input Signal short!
led oscillating!
Power supply + 68 -68!
+ -12/14 Volt bias!
I did not modify the components!
the name of the song and not know a mix!
jcoelhogsia,
please test you amp with this step and tell me the result :
1-connect input , output and all supply voltages connections.
2-apply mains to transformer (+/- 68V)
3-now , apply bias voltage to amp
4-watch active LED status (tell me)
5-now , play sound with lowest volume and see the result. then increase volume and see the result.keep me posted.
