First DIY Direction/Recommendations / Help
Good day all!
Background: I have a 4 watt SET tube amp. Right now I am using it to power a pair of B&W 601 S3 bookshelf speakers. I am happy except for its low end response. They can reach 60 Hz on a good day and are 89 dB efficient.
Looking to build something that is more efficient, without a x-over to ensure max power is going to the drivers.
Looking for something that I wont feel like I *need* to run a sub with.
  • Tang Band W8-1772 in a BLH, not sure which one
  • Mark Audio A12P in Super Pensil or Pensil 12.2
  • Betsy-K in WIBAQ
  • Dayton Audio PS220 in ?
Is 8" the wrong size driver to be looking at?
Any recommendations are greatly appreciated!
Thanks!
FWIW A12P is more like 6.5", not 8". The Super Pencil makes decent bass, and works well with low power. I haven't used my sub in ages. It's definitely not a bookshelf size speaker thou.;)
jeff
Thanks Jeff, I am not opposed to a larger speaker by any means.
I like the price of the A12P speakers, the super pensils seems easier to build than a BLH as well. Good for the first time DIY.
ron
Hello,
look my double horns, specially for Tubes,
no bass resonanz, down 35 Hz, 98 dB 1w 1m
Do you have an example link/plans/recommendations you can send me?
The SET is fantastic, I wanted to open it up to its full potential by moving to a single crossover-less speaker.
Sorry I have forgotten all the tube stuffs.
Audio is a wide ocean. You must first pick your boat type: high efficiency class-A system or power hungry solid-state.
You may find a lot of joy sailing in the tube ocean. Many frustration in the solid state one :D Just kidding.
