plenty on here if you use the search function
You will need more than 2 pairs of transistors per channel (more like 8-10 pairs), and certainly better devices than 2955/3055, to get 300W into 8 ohms... and at least 85V supply rails.
It will need a huge heatsink, and will not be cheap.
That was modified OCL 150W. I post the original here: http://www.diyaudio.com/forums/solid-state/168554-based-hugh-deans-aksa-55-a-14.html#post2225687
can i get the part list of this circuit
cant u see the top layout?
Are these any help Mr.NazirDigi, made from your photos only
dear sir,
what is the dimension of this pcb.thanking you,oh yes can u provide me this pcb circuit details thanking u again yours ever masood
GOOD
Thank you, for your great contribution
Please see this thread: http://www.diyaudio.com/forums/solid-state/269874-300w-ebay-amplifier-3055-2955-a.html
This amp use same topology and much more better: http://www.diyaudio.com/forums/solid-state/236138-2sc5200-power-amplifier-7.html#post4262125
- 300w power stereo amplifier with pcb layout
