Pioneer VSX1020 like TGM1 ?
I pulled a dead Pioneer VSX1020 out of the trash (not dead, but powers on, then waits, then cuts out and powers on again and again and again) and didn't see any easy way to fix it so pulled it apart instead.
I was interested to see that the amplifier design was very simple indeed. But even more surprising was that it appears to use a resistor between the output and the top of the LTP to inject 2nd harmonics !
Eventually I found a free service manual on-line (if I'd found it earlier I might have been able to fix it but now it's trash). The schematic of interest is attached. Look at resistor R1209SBL. If you look at my TGM1 amplifier thread you'll see the same thing was tried out in the initial design phase. Am I reading the schematic right ?
Joined 2010
Hi Bigun, 470K is certainly not much coupling but I would suggest this and many related
tweaks have been lurking in "high-end" amps for many decades - toob era even! :wchair:.
The compensation caps C12245,12235,12115 are also odd...Was this a "trim with the
wire cutters" grade amplifier or do you think they ran out of 250 pF caps? :D
The bulk of the parts are through-hole on the front side, but there are few parts that are surface mounted. These 3 caps are tiny surface mount caps on the backside and all three are populated on the pcb for each channel. In fact I'm not sure there are any other SMD parts on the amplifier pcb.
I see phase lead (33pF) but I don't see any Cdom. The Vas compensation seems to depend on a 47k shunt load on the collector and a kind of zobel between base and -ve rail. The Vas is degenerated with a 47R.
Interesting, isn't it Bigun? It seems they would not achieving for the lowest THD.
Yes indeed, you are probably more familiar with this design than I ;)
I like that it has no Cdom, a different compensation scheme than I've used on anything I've built.
I'm getting more curious about it.
First you build it to make it stable, then you break it to
obtain good sonics.
Some of us have learned the lesson.... thanks God by that!
Tune and detune.... in radio frequency the quality goes in tuning... in audio in detuning.
Not only the 470K dear Bigun.... watch it carefully.... we have more tricks there.
I'm doing the lottery federal investment .... 500 bucks per month .... one day i will have Millions of dollars and i will move to the U.S. to start the real Dx Corporation ... you Bigun, Hugh Dean, and some others will be invited .... can you imagine what we gonna achieve together?
We gonna research separatelly..each one of us creating our own secret "pearl" amplifier....the task is:
- Beat me if you can!
The winner amplifier will go into production.
After that we cooperate...tips and tricks gonna be shared in between us...then we gonna start all over again..
Ahahahahahahah!..... we gonna be the most terrible nightmare to the competition! (Dx, Aksa and Bigun) ... while poor guys will be trying precision on amplifiers..we gonna be searching sonics!
Observe that we gonna use the major powers we have in humans..the instint of competition, also the cooperation and the main one in thousand of years of human culture...the tribe, the clan, the Union (guild).
regards,
Carlos
The one that discovered some "special resources" in the first place
Was Hugh Dean.... he have switched on a "light" inside me.
You know dear Bigun...you watched the movie 2001, Space Odissey.... do your remember about the monolite that made humans evolute....that resistor is alike a monolite (one of them)... evoluting us a little bit more.... touching the monolite we learn how to use tools...we became better chimps.
Humans are so stubborn that Hugh have explained the stuff many times..also i did that..now your are pointed that dear Bigun...and nobody believe...nobody understand the gift we are giving to them...also they do not believe in extra terrestrians.... and we are here.
There's a say in Brasil that shows the stupidity:
- "Eu não sei, não quero saber e tenho raiva de quem sabe!"
- "I do not know, i do not want to know, and i hate the ones have the knowledge!"
Hugh Dean is the Master.... he sniff good things... detect things, discover things... his car is a Toyota.... the best one!
Our forum is now a days having a lot of propaganda... sadly this is happening.... i see the donate button have not worked... sadly we are entering the market place...also here... a pity.... add block engaged.
regards,
Carlos
Joined 2010
.... These 3 caps are tiny surface mount caps on the backside and all three are populated on the pcb for each channel. In fact I'm not sure there are any other SMD parts on the amplifier pcb.....
Ah....the penny drops. This may have been a cap. grade issue and larger values weren't available in that type. Perhaps the designer was at pains to avoid non-COG, NPO or similar ceramic material for the cap, necessary or not.
I'm waiting for the big win my friend !
But I don't think Class AB is the way of the future. I am sad, but I believe it is a dead technology. It does not mean we can't enjoy making Class AB amplifiers, I enjoy it a lot, but Class D is the proper way, in my view.
Pioneer is using ICEpower Class D amplifier technology
Please forgive my intrusion, but I must confess I am partial to Pioneer Electronics.
The Pioneer VSX-1020-K listed at $549 on Pioneer's website can be found for less than $300 on Amazon.
For the price, it is an amazing receiver, and the sound quality is right up there.
To find out more about Pioneer's Direct Energy amplification:
Specs:
Personally, I really like the sound, performance quality and reliability of Pioneer. I still have a Pioneer SX-1250 from 1974 receiver driving the left and right main bass Pioneer HPM-150 speakers from 1976. I'm using bi-amp on those.
Wiki on ICEpower:
The class D3 amplifier in the Pioneer Elite SC-65 apparently uses little or no feedback at all, with great linearity and efficiency. Music to my ears!
Specs:
Now from a DIY technical perspective, I'd like to understand more what this D3 class amplifier is all about?
The trouble with our times is that the future is not what it used to be.
~ Paul Valéry
Price is what you pay. Value is what you get.
~ Warren Buffett
I'm going to be turning the 7 channel amplifier pcb + heatsink into a new amplifier for my HT system so I'll get the 'sound' but not all the benefits of the rest of the circuitry. I could easily buy a new one I suppose, but then where's the fun in that ? - besides, if I do buy one it will be their new Class D receiver. I saw one at The Future Shop. I think Class D is the ideal approach for home theatre where it's necessary to put a lot of power into a relatively small space. It would be interesting to hear it.
To find out more about their D3 design it would be nice to have access to a Service Manual. Looking at the design of their Class AB amp I can say that I have a great deal of respect for their design talent.
