bass speaker help
Ex-Moderator R.I.P.
Joined 2005
new idea for a bass horn
could be the next project
based on my experiment here, I have concluded a big midbass horn is tricky
but also that it reproduce with a special big tuneful sound, and almost addictive
Ex-Moderator R.I.P.
Joined 2005
I suppose you could add ports to the rear chamber to improve LF response a little.
Hornresp has this option.
just realised why not to use ordinary medium Qts drivers for front horns
and pretty obvious, peaked low rolloff in a small back chamber :clown:
apart from that, a 150hz horn looks easy
use all the available space for a backchamber it might still be possible
btw, I tried a small Onken slot port calculation with the 12" Sovereigh, and looks like it would work nicely
Ex-Moderator R.I.P.
Joined 2005
latest crossover revision......
another update on my weird xo
I can now fully understand why some people wisely avoid multiways for bass guitar
several times I have experienced tuning and pitch to go complete wack(off)
its certainly not simple at all
next crazy project, big weirdo 18" 'fullrange' :D
Which modeling program are you using?
It's certainly not been easy, but in my case I have been really happy with the results once I threw enough time (and money!) at it.
Ex-Moderator R.I.P.
Joined 2005
ears :D and my guitar ;)
actually, my ears just went complete wack
one ear closed, and it hurt a bit
changed a few resistors(again)
ears improved immediately
as did my playing :rolleyes:
sound as such doesnt change much really
its all mainly phase issues
sure, crossover is not too good, its crap
just fooling around, needing components
in the meantime, I put my ears at risk
and its not a joke
Ex-Moderator R.I.P.
Joined 2005
Depending on how high the basshorn has to go .....
100hz to 2khz would be ok :p not sure folded is so good
anyway, I removed the tweeter series inductor
sounds better without it
it dealt with some electronic issue I had with effect units
and those were removed a while ago
the only effect box I use now is a compressor
and only because it gives a little exstra gain I need
This is a quite elegant looking solution but I fear that it doesn't differ that much acoustically from the other horn/reflex hybrids that are around. But it might be a little more complicated to build compared to the latter.
Do you know the cube shaped front-loaded horn from "Klinger". It is quite compact with a side-length of 60 cm. But you would of course need a high-efficiency midrange that goes quite low.
Charles
Ex-Moderator R.I.P.
Joined 2005
it is midhorn with apperiodic backchamber, not reflex...thats the difference
and I wont risk loosing it because of a too high port tuning ;)
anyway, I bought the plywood today
I need to test it before I build more
2 or 4 would be cool :D
