Dubai, can you read german? Nothing against ATLAS,
I ordered according to HB:
Paradise – Transistor matching | Holger Barske
I am new to transistor matching so the question might be silly, but would a device such as the following be useful?
Found at Reichelt: ATLAS DCA55
Your feedback will be appreciated - thx.
dubai2000
I will, tonight, have a look at them. At first glance it seems the V(be Q102) is a bit low, and that this is debit of the current unbalance.
Yesterday I did not manage to do this, I will try to do it this evening
No problems. Take your time.
Joachim, I'm worried about transistor matching how close do they actually have to be?
Is it more important to have a good balance between 327 and 337 or more important to have them matched within each quad, ie 4 327 with the same value as each other?
I can get good quads, ie 4 x 327 with identical values, or I can get a good balance with a looser match yielding a combined HFe that matches between 327 and 337. But I can't get closely matched for both...
Failing that does anyone have 8 337 with an HFe of 400?
I will put my list up later today
Hopefully this will spur on some responses.
All soldered up just wondering about how to wire up the loading resistor? Am i right in thinking it just goes from signal to ground. If so can I place it at the input on the pcb
Sorry, but I think you have mounted the two caps on the upper right (6800µF/6.3V) in the wrong direction.
I had noticed that, amazing that at the time I hadn't seen it. Can't see the wood for the trees.
I do however have other issues, like none of the LEDS lighting up on one board- they are all good though. And 4 of the LEDS on the other board having shorts. Of course they are 4 of the LEDS under the heatsink.
Much work to do, sorting out faults and building a PSU I can actually trust rather than the one I borrowed that i'm not 100% sure of.
- Analogue Source
- Paradise Builders
