Used in the Culture Vulture Stereo Distortion Unit. See description of sounds in the user manual.
http://www.thermionicculture.com/im.../CultureVultureValveDistortionUnitManual9.pdf
Ian
Ian
yes...connect G2 to plate and you have a triode...
Tony
Yes, I want use as triode.
Aldovan
If I connect the G3 of the 6AS6 to cathode , this pentode can work fine for audio pre-amplification ?
You can make it into an electronic volume control if you connect G3 to a variable source of DC, like 0 to -18V or so. See the schematic below:
pw2.netcom.com/~wa2ise/radios/elvctube.jpg
I connected 6SA6 pin2 to pin7, to substitute 6ak5/403a/403b/5654/ef95. Obviously you can get good price on 6ak5 family already but as LittleDot and Yaqin amplifiers are getting popular, some expensive 6ak5 like WE403, Mullard/Siemens EF95 are getting a bit pricy. You still get same performance out of 6AS6 at about half price tag of 6ak5 in general.
- Tubes / Valves
- 6AS6 is useful for audio ?
