I'm having the strangest problem this morning, could someone please verify the following for me? These are the pin assignments for the Amanero feeding a TI PCM5102.
Amanero Pin 3 - DATA to PCM5102 Pin 14 DIN
Amanero Pin 4 - CLK to PCM5102 Pin 13 BCK
Amanero Pin 5 - FSCLK to PCM5102 Pin 15 LRCK
Amanero Pin 6 - MCLK to PCM5102 Pin 12 SCK
Thanks in advance!
Thanks in advance!
Has anyone tested DSD with the new firm+driver?
Doesn't work for me-one channel of DSD works fine, the other channel is just noise. Works fine with any PCM, but new driver/firmware doesn't make DSD work for me. I suspect it might be a faulty board.
Don't know what to do now, tried everything but no L&R DSD which is why I bought this device.
@Supra, were you using a B-III?
My findigs were the same.
I am using a Buff2.
Brings up the question - is anyone getting good results with non-Buffalo DACs?
Another question- is anyone getting proper DSD operation, apart from GLT and his very complex foobar implementation?
Are there faulty units coming into the market?
Try to modify buffer length. In my case, works fine with little lenght.
DSD is working fine for me now using the setup detailed on glt's blog (great info - thanks) using current driver (version 1.056) and Buff2.
Supra - have you tried updating the firmware (Amanero Technologies)?
- Vendor's Bazaar
- USB to I2S 384Khz - DSD Converter
