Need wiring help
Please help before I pull out what little hair I have left :confused:
I am trying to wire a circuit that goes from ac adapter/charger to a nimh 12v, 10AA battery pack to a switch and led light then to a Sure 2024 amp. I have spent hrs. trying to get it right but there is something that is escaping me. A simple diagram would be so much appreciated.
Thanks!
Thanks!
You trying to power the amp through the LED?
Battery '-' to '-' or 'ground' (earth) terminal AND the 'cathode' (look it up) of the LED. '+' terminal of battery to one terminal of the switch. Second terminal of the switch to '+' or 'power' on the amp AND a resistor of at least 1000 ohms. Other terminal of the resistor connects to the 'anode' of the LED. More then 2 terminals on the switch? Either get a 2 pin switch or figure out which 2 to use.
Presto. Get some Rogaine to grow back the hair and enjoy the amp.
Thanks Stratus
I think I have completed the wiring as per your instructions. Please look at the diagram and tell me if I have it right.
There a 2 problems-
1- the voltage at the amp is only around 9v although the supply is supposed to be 12v
2- it doesn't work at all off the battery even though the green light is on on the charger
  • Portable power wiring.pdf
Is this what you would like to do?
