You need to have a capacitance meter, some high end digital mutimeters have them built in.
Cheers George
George,
Thanks and my meter has that built in. Will report after checking.
Albert
I pulled the pair of interconnect and measured with my DDM, and it was read zero.
I took another pair of silver interconnect and again measured with my DDM, it was also read zero too.
I try this silver pair on the system and to my surprise it sounds so good that all highs are presenting pretty neutral and vivid. Now I can compare my lightspeed with my 26 line amp. Will test it for a longer period to comment.
Albert
Albert
Cannot be zero Albert, are you measuring from center pin to shield at one end, other end open?
Cheers George
No. I measure from one end of center pin to the other end of center pin.
Did I do something wrong ??
Yes, measure from center pin to outside (sheild) at one end, the other end not pluged anywhere.
Cheers George
OK, the one I've been using is 0.157nf/157pf with ofc. The one I'm trying is 0.082nf/82pf with 22 awg pure silver. The 82pf one sounds open, will report after serious listening.
Albert
Hi Albert, I recommended to you in the return PM that you should have no more than 1.5mt at <100pf per foot.
The Lightspeed is flat from dc to over 300khz it self.
Then determining factor becomes the interconnect capacitance for the hf rolloff.
And any source coupling capacitors will determin the bass rolloff, none if the source is solid state dc coupled then bass rolloff in not an issue.
Cheers George
Cheers George
Cheers George
George,
The following is my set-up for the moment, direct from cdpro transport RCA out with opamp 110 ohm as of specification. 3 foot interconnect measured total 82pf to 6C33C OTL power amp. Sounds terrific and all spectrum is balance and neutral without any exaggeration. sound stage is very wide and deep, very deep and dark indeed. Will let you know more and thanks for the help.
Albert
All that should be fine, the OTL'S are probably over 47kohm input, so all is good.
Cheers George
Yes, the amp is 100k
George,
First of all I have to thank you again for your generously release your design and all the helps follow through.
I have this volume to compare with my double choke 26 preamp and I can tell you that I love this volume more, a lot more. The density of sounds is one of the kind and it is, as I said on the last post, so smooth, liquid and detail. Background is very dark and very deep.
I highly recommend this design. This is simple enough for the newbie like me.
Albert
Albert
Thank you Albert for your kind words, and your views on the sound. I wish all the emails were all like that, instead of some that say I am trying to ruin the preamp industry (one guess which sector those came from).
Most sources these days have so much output that they can send 99.9% of poweramps into clipping, so why the need for hideously expensive preamps with their extra gain and active circuitry that only adds colourations and distortions.
I believe and so do many owners that if your source (cdp dac etc) is low in output impedance, which most industry standard sources are.
And your poweramps input impedance is >47kohms (which is the industry standard) or higher (tube generally are much higher).
That the Lightspeed Attenuator the most transparent/dynamic uncoloured way of transferring the source's signal to the poweramps yet with control over the volume.
The only way this was bettered (only slightly)to mine and others ears, was when I demonstrated the source directly plugged into the poweramps with no Lightspeed Attenuator in the signal path. This source had a digital domain volume control and was use in it's top 25% of full output, any less than this and the dreaded bit stripping occurred taking the resolution from 16bit down to 14bit and further the lower the digital volume control was taken below 75% of it's full output. But the trouble with using it this way is that most systems would want the digital volume control at less than 60% for normal listening level where then you would loose resolution down to 12bits or less. So the Lightspeed Attenuator is the closest way to having a direct connection between source and poweramp there is.
Cheers George
Cheers George
Everyone has right to talk and I suggest him to pay more attention to his product instead. If he can't sell his product to people it means that he should pay more time to improve his product instead of saying bad words to hurt others that he shouldn't. Hifis /cars are the same. people have money and didn't want the hassle and they pay mega bucks for the brands that they prefer, and most importantly they can show off to people who admire. A good and not pricey compact car can do the same and take to to the location you want, nothing wrong with that.
Like I said, you aim at those with ears and they sell their products to somebody with money and love to show off that is all. I the one don't want to spend that kind of money for the product that I don't like. This is why I start DIY. But don't make me wrong, I have ears.
I totally agree.
George, Be patient and don't mad with whatever words out there. You're just aiming at those with ears. Let them decide what is good and bad. I've been making many amps and speakers for the last 45 years but I still calling myself a newbie for the reason that I'm still learning everyday, there is still lots of new things that I don't know out there. Lightspeed is the one. At the beginning, I had a wrong idea in mind that I should go with some complicated design to have good sound. Now I strongly believe the KISS form. Let people out there making whatever they think is good for the moment, and I am sure they'd come back to the KISS form later on.
People who don't believe, please make one for yourself and try.
Albert
I totally agree.
Albert
Albert
I must agree. I am using George's invention now for 5 years and continue to be amazed at the sound. As I continually improved the source, the lightspeed showed itself to be completely transparent. This was with a tube output DAC and a SS amp that has lower than the recommended impedance. I am now building a tube amp and look forward to experiencing the full potential of the lightspeed.
My 6C33C OTL with 100k input - designed by Hans - sounds so good that I haven't had heard before. I even gave up my AN DAC and the choke load 26 pre-amp for the lightspeed.
. . . an SS amp that has lower than the recommended impedance.
I recently added a second upgraded Quad 303 power amp to my system - its input impedance is nominally 20k so my Lightspeed-circuit volume control is driving 10k per channel. To my surprise and despite breaking all the rules, it works (and sounds) fine.
Just regarding my stated minimum input impedance of 47kohm or higher, this is only a comfort guide.
So long as the source cdp/dac is low output impedance, the Lightspeed will still be comfortable looking at 20kohm poweramps.
As we conducted a 20 audiophile listening test with a tube amp that was specially modded to have a switchable input impedance from 300kohm down to 10kohm and could be switched while playing.
We started with the high 300kohm input and came down in increments and not until we got down to 33kohm, only then did 5 or so of the audiophiles think they heard a very slight compression, and even then they were not 100% sure.
Many Lightspeed users that I know are using it with 20kohm poweramps and still say that even if it's not at it's optimum, it's still sounds better than their expensive active pre's they were using.
And thanks very much for the positive comments dtses, wlowes, albertli and ryelands.
Cheers George
Cheers George
- Analog Line Level
- Lightspeed Attenuator a new passive preamp
